SOLD2008 Z06 2lz H/C/I/E
2008 z06 2lz
Blk/blk 20,000 miles $36,000 Ls7 Cylinder Heads done by West Coast Cylinder Heads ARP Head Studs CNC Stage II Port & Polish for optimal flow Mulit-Angle Valve Job Milled .037 to bring static compression ratio to 11.8:1 Replaced Stock Exhaust Valves with solid Stainless Steel Valves C.H.E. Rocker Arm Upgrade C.H.E. Manganese Bronze Valve Guides Tumble Polished Stock Titanium Intake Valves Ragin Racing LS7 Camshaft Stalker Crane Cam Specs 224/246 .660/.660 Lift 115 LSA 5 degrees of overlap Comp Cams Custom Length Push Rods for Proper Preload Marley High Performance Duel .700 Lift Valve Springs w/ Titanium Retainers Lg Motorsports Exhaust Stainless Steel Long Tube Headers 1 3/4 inch Primaries Stainless Steel High Flow Catted X Pipe Corsa Exhaust w/ Black Tips Air Intake System Halltech MF103 Beehive Cold Air Intake System FAST LXR 102 Intake Manifold Painted Silver Holley Fuel Rail Nick Williams 102mm Throttle Body Elite Engineering Oil Catch Can Wheels & Tires OEM Black Zr1 Wheels Michelin Pilot Super Sport Tires Miscellaneous Custom Valved Doug Rippie Motorsports Bilstein Shocks 160 Degree Thermostat NGK TR6 Spark Plugs High Temp Plug Wires 2012 Centennial Steering Wheel Shift Light set to 6,800 RPM Norris Motorsports Professional Engine Assembly and Degreeing of Camshaft Straightline Performance Custom Dyno Tune https://cimg9.ibsrv.net/gimg/www.cor...b1dc2be32c.jpg https://cimg0.ibsrv.net/gimg/www.cor...a3f1f72ca7.jpg https://cimg4.ibsrv.net/gimg/www.cor...71c3716e41.jpg |
Ttt
Originally Posted by keith2547
(Post 1597322633)
Ttt
location? Stock clutch? All black interior? |
Chicagoland area
stock clutch black interior |
PM'd you but haven't got a response. Could you send me your phone number?
Z
Hey what’s your number? I’m interested in your Z06 |
Sale pending
If it falls through, let me know. I really want this Z06 |
Your Z06
Hi I’m interesting in your car, I live in Orland Park and can pay on spot. Thank you Arthur |
Is this sold? |
Sold
