C6 Z06 Fender Vents
Wondering how to remove the fender vent scoops on a c6 z06?
Most concerned about the front fenders and wondering if the process is the same for the rears? Thank you in advance! |
Process for Fronts...………..
Raise and support vehicle. Remove the front wheel and tire. Remove the rear portion of the front wheelhouse liner. Remove the fender ornament from the inside of the wheelhouse opening by releasing the three integral tabs on the inboard side of the front fender ornament. Similar for rears, although there also will be some "noise insulation" material to remove from both the fronts and rears as well (packed in a plastic bag) |
Not sure if you are talking about the same thing I did here, but check it:
https://www.corvetteforum.com/forums...n-them-up.html |
