Check Engine Light on
Had a real nice track day on Friday but it all ended with the the check engine light turning on. I have a 2017 GS with an Edlebrock e-force stage 1 kit on it. the only other mods are a Borla x-pile and exhaust. The tune was done by edelbrock by mailing in my ECU to then and then reinstalling it when I put the kit on back in November. All has been working well until this Fridays track day. The check engine code it threw is p0171. System too lean Bank#1. Have any of you with an e-force had this issue. If so, what was the fix? If not, do any of you know where to look first since it can be one of a 1/2 doz reasons.
Thanks -Ed |
ttt
I would pull your 02 from the drivers side & look at it. Per say they tune there stuff to run rich on the car just due to running them on the track. But 02 sensor may be going. Are you could reset the code & try it again. But for sure I would give them a call & get what they tell you to look at... Robert
Originally Posted by robert miller
(Post 1597403775)
Originally Posted by Ed'sC7
(Post 1597404115)
I'll do that - Thanks
Ttt
I dont think you guys both done this but also if you put your fingers prints on those ends, I have been told they can go bad also. Robert
