Air conditioning heater control
How do I get the dang thing out of the console. It doesn't want to come out. 1975 Corvette.
Define "doesn't want to come out". Remove the console trim plate to get at it. There may be a screw or two holding it in the bracket.
The assembly instruction manual (AIM) has a couple of diagrams showing the installation and the vacuum and electrical connections. :thumbs: |
It is not just going to come out. There is a lot of parts you need to remove to get this out due to the one cable that goes over to your heater box...and you also have the vacuum hose connection.
The hand brake cover needs to be removed...then the console CAREFULLY needs to be removed. This can be a ROAYL PAIN due to the possible two nuts that hold the shifter console to your gauge bezel. Trying to get the control off of the thin metal plate is bolted to is NOT EASY if you try to do it without taking more parts off. When I do these...I remove the shifter console ALONG with the gauge bezel as a unit. This will also cause you to remove the map pocket dash panel on the right side so I can gain access to the end of the cable and remove it if needed. This allows me to slide the entire console and gauge cluster back a little bit and allow more movement so I can get that steel support bracket that is holding the control out of the console and laying on the floor. Then the control is sitting there all by itself and I can replace it and then put all of what I removed back in. I disconnect all of the wires to the gauge cluster and radio and take the entire assembly out of the car so I can get to the control and work in it. I have dealt with this so many times the procedure I use is actually faster and allows me to get to fasteners that are normally a ROYAL PAIN to deal with. This control is NOT an easy part to install. And I have tried different ways to try to speed it up ...but the way I have mentioned may cause you to take a lot apart...it actually goes a lot faster...as I have tested and found out. Or do it as you see fit. DUB |
You have to remove the Bowden cable(s) at the front of that control. THEN it will come out. :D
There is only one cable on an A/C control..and it can be detached at the heater box so the control can slide back so you can gain better access to removing it.
Trying to remove the cable without getting the console out of the away and still installed is a futile task at best. It can be done..but you would be fighting it the whole way...and can break the cable housing mount point also which is plastic. DUB |
The cable can be disconnected at either end. But it MUST be disconnected to get the control head out of the console. (point made in post #4)
Originally Posted by 7T1vette
(Post 1597421486)
And prying the control UP to gain access to the screw that holds the cable... it puts it under tension. Along with possibly damaging or putting unneeded stress on the vacuum hose connection. Those that need to do this....do as you wish. If you are successful by not removing anything but the shifter plate...GREAT. If you break the plastic end off of your cable. You will be removing the map pocket dash panel to change out the cable. Your call on how you choose to do it. DUB |
