current tire deals at tirerack and elsewere...base models.
Yes, it should "elsewhere"...sorry.
I sometimes cruise TR just for the heck of it. Just went there and saw quite a few promotions for tires for the base model C6. I realize many of you are not interested. For those that might be, deals on a full set of tires, after promo or rebate, currently run from $528, on up. For example, the Firehawk Indy 500, which is a pretty good Summer tire, is just $603 for the set. If I needed a set of tires, I would go after one of these deals. Many of the deals are also available at your local tire store. Just thought I would let some of you know. |
Originally Posted by buckmeister2
(Post 1597547456)
I sometimes cruise TR just for the heck of it. Just went there and saw quite a few promotions for tires for the base model C6. I realize many of you are not interested. For those that might be, deals on a full set of tires, after promo or rebate, currently run from $528, on up. For example, the Firehawk Indy 500, which is a pretty good Summer tire, is just $603 for the set. If I needed a set of tires, I would go after one of these deals. Many of the deals are also available at your local tire store. Just thought I would let some of you know. Thanks Clark |
Originally Posted by get smart
(Post 1597550246)
Is it ok to buy a set of front tires that are different brand from rear tires? My fronts are worn and need replacing. I want to later on change rears to same brand as front. Are any run flats cheap?
Thanks Clark |
for the most part, if you find a good price somewhere online, Discount Tire will match it.
(Post 1597550246)
Thanks Clark |
You will have no issues mixing different brands. Just make sure the fronts have the same brand are the same as well as the back. |
Originally Posted by farmington
(Post 1597551248)
Thanks Clark |
(Post 1597551248)
Been dealing with Discount Tire exclusively for almost 30 years and never have had an issue. If I can get that service with the prices I see online? Win-Win. |
