I ran 40+ cans of torco through my old setup. Yes it leaves a red residue? So what? Are you taking the spark plugs and piston tons to a beauty show? What is the impact of that residue? As far as I can tell and see, nothing. Just like burning gas can leave black carbon residue, so what?
Originally Posted by MarkC
(Post 1597577615)
in Virginia E85 is available on the military bases but I am unawhere of any nearby stations that sell it. Since you are military you probably take advantage of fuel sold on base. Btw, I spent 3 months at Camp Pendleton in early 1971 and a 2 week summer camp around 1974. I was in the local Marine reserve unit which changed over to amtracks in 1972. Semper Fi |
Originally Posted by Unreal
(Post 1597577777)
Correct me if I'm wrong please, but my understanding on carbon deposits is that they lower the detonation threshold, which is kind of important if you're pushing compression ratio limits. |
Originally Posted by MikeOC
(Post 1597577903)
Just spit balling about how Josh can run 91 safely at 14:1.
Originally Posted by Josh B.
(Post 1597577950)
I drove like Miss Daisy, which was odd for a yellow corvette with shift sector stickers on the doors. Do 70 mph in the right lane and downshift into 5th on all hills :) Keep load down, no lugging. Dave Steck simply told me "It'll be fine, just don't do any Texas Mile runs that way". Even when I topped off on 91 octane I still had like 3 gallons of E in the tank and ethanol content was still like 20%, so better than pump 91 at 10 percent content.
(Post 1597577903)
I can't speak to the Torco residue, I was just wondering if ethanol would remove it. Just spit balling about how Josh can run 91 safely at 14:1.
Some serious race car stuff going on here...
Originally Posted by Mordeth
(Post 1597578498)
After some Amsoil break in oil I'm thinking I will make the switch from my usual 5w-30 Amsoil signature series to something like Amsoil Dominator 10w-30. What are your thoughts on oil use for my street application? Rev's might be as high as 8000rpm, depending on the curve. |
Originally Posted by MTPZ06
(Post 1597578373)
Agreed, and does the rust stuff behave similarly? Short and long-term effects...does the rust stuff degrade O2 sensors, wideband AFR sensors, spark plugs, catalytic substrate, etc. Obviously all of which can be replaced at some sort of cost...but does it accelerate the rate of replacement? Who knows?
eff I don't run cats, don't run rear 02s and I replace my sparkplugs once a year either way. So the orange crap is meaningless to me. It also has no apparent negative effect on the operation of the engine. I simply use 1 bottle per tank of gas at the track and am about 102 octane. Very simple and easy and I don't have to worry about finding race gas or E85 or worrying about detonation/pre-ignition (been there, done that). |
(Post 1597578373)
Drives Like Stock Camshaft
Just received the cam from Comp. The MSE finishing process is awesome. Very smooth, zero sharp edges. The quality only seems to improve as time goes on. https://cimg7.ibsrv.net/gimg/www.cor...201842352.jpeg https://cimg8.ibsrv.net/gimg/www.cor...177dd5206.jpeg https://cimg5.ibsrv.net/gimg/www.cor...9caa865bf.jpeg https://cimg4.ibsrv.net/gimg/www.cor...5e1687a81.jpeg https://cimg6.ibsrv.net/gimg/www.cor...6304526f1.jpeg https://cimg3.ibsrv.net/gimg/www.cor...59094cda3.jpeg |
(Post 1597578565)
I use Boostane Professional. I have tried both Torco and Boostane but I like Boostane better as you need less of it to get to the same desired octane level and it also does not separate and settle at the bottom of the gas tank. Boostane stays suspended via a proprietary carrier (unlike Torco which can settle). See here: https://vimeo.com/101450801
(Post 1597578607)
Those are all good questions. I know after running a few tanks of non torco through, plugs would look fine again. My pistons/chambers/etc showed no orange after a few thousand miles of e50-e85. So I would say yes it burns off. All I ever here is it turns stuff orange, but no one can say what effect that has besides stuff is orange.
(Post 1597578550)
Thank you! I'm really open to your all's advice on best directions. Especially when it comes to setting up this new valvetrain. The T&D's have that very narrow range of adjustment so I'll need to be on top of my game when I take my measurements. Using test springs and then full springs to check for deflection. I'm thinking I need the most precise pushrods I can get so I don't know if Manton or Trend or Smith Brothers will be my best choice. Piston to valve clearance will be especially critical with these heads since the valve locations are moved .080" up towards the intake flange, making radial distance a bit less, especially with the larger 2.250" intake valve.
After some Amsoil break in oil I'm thinking I will make the switch from my usual 5w-30 Amsoil signature series to something like Amsoil Dominator 10w-30. What are your thoughts on oil use for my street application? Rev's might be as high as 8000rpm, depending on the curve. I personally like Trend, and is what I use. Trend literally developed the Spintron machine in the 90's. Google "Bob Fox" from Trend and Randy Dorton from Hendrick Motorsports. But Manton and Smith Bros are also great and their turn around time on custom lengths seems to be faster than Trend. My Trend were also all custom length after very precise measurements by me due to the limited travel lifters I use (and obviously some other factors). For oil, you should run Amsoil Dominator (or Zrod) 10w30. Message me your address and phone number and I will ship you a case on me. |
(Post 1597578667)
Just received the cam from Comp. The MSE finishing process is awesome. Very smooth, zero sharp edges. The quality only seems to improve as time goes on. https://cimg7.ibsrv.net/gimg/www.cor...201842352.jpeg https://cimg8.ibsrv.net/gimg/www.cor...177dd5206.jpeg https://cimg5.ibsrv.net/gimg/www.cor...9caa865bf.jpeg https://cimg4.ibsrv.net/gimg/www.cor...5e1687a81.jpeg https://cimg6.ibsrv.net/gimg/www.cor...6304526f1.jpeg https://cimg3.ibsrv.net/gimg/www.cor...59094cda3.jpeg Whats its name? Last cam had a name...how about this one? |
What was the last ones name? That is one montrous cam for real.
Originally Posted by Innovate
(Post 1597579294)
https://cimg7.ibsrv.net/gimg/www.cor...2b82b9baa3.gif |
(Post 1597579280)
My word...what big lobes you have Josh. :D
(Post 1597579364)
Last one was "hot for teacher". This one needs a name...like Satan's Helper. :rofl:
(Post 1597578702)
I would use the largest diameter push rod that fits in the hole. Don't worry about weight of pushrod. Worry about weight on the valve side. Want to know why I don't use 1/2" diameter pushrods? Because they don't fit, otherwise I would. So I use 3/8" tapered with a .130 wall. The pushrod is the slower moving part of the valve train, so adding a tiny bit of weight here isn't a problem. You would much rather have a pushrod that does not deflect and maintains/spreads the load properly, in addition to the thickest wall possible to resist compression, even if heavier. This greatly assists in valve train stability. I realize you likely know all of this, but those are my personal thoughts.
My engine guy was actually talking to me yesterday about two different push rod sizes. Said same thing as Mordeth, biggest rod that will fit in the hole. So 7/16 on thick wall on intake and 3/8" something on exhaust. Or maybe the opposite, but something like that.
