1985 Corvette motor question (heads)
On my 85 I had developed an intake leak, so I took it apart and found that the motor isn't original to 85, it's a roller block with roller lifters, but with the stock 85 heads. After taking a closer look I had 3 valves that were about to lose their keepers, and so I yanked the heads and took them to a machine shop. I get a call that the heads are basically shot and not worth the money to being back in shape, so..... I began looking for heads, Summit, Jegs, etc. I'm not building a race motor, just want a good dependable daily driver. I began noticing that all the heads state will not work with factory roller cam or either will not work with TPI. Has anyone had an issue like this? What are some recommendations? I'm wondering why they wouldn't be compatible with TPI? Is it because they don't have an EGR passage?? Any help is appreciated. I am perfectly OK with cast iron heads too.
Some tpi intakes have a different bolt angle toward the middle. Straighter down if you will. That is the difference.
624 heads are pretty junky. The summit iron heads, 165cc runner, are decent. They are dart heads, have egr and would be a nice mild upgrade permitting intake pattern. (I don't remember if vettes were different or thirdgens.) That's my suggestion. |
..... Look for a set of the '86-up vette aluminum heads … they can be had for as little as $300 pair … but at $600 they'd be a better deal than ANY iron heads …..
Get a pair of 88 and up 113 heads. You can find them reasonably priced and will bolt right on and be better than those Summit iron heads
My car came with a lot of paper work , i have the engine build sheet (355 cu in.) and in mine in the cyl heads line it states: Dart Iron Eage (200 in. Runners, straight plug)... |
Originally Posted by IBVETN2
(Post 1597579892)
(Post 1597579892)
For an economical upgrade, the iron 993 heads would have the same CR, better flowing ports than the 624 heads, compatible port locations, and use the same valve covers. :cool: |
when you guys say 113, 624, and 993 what exactly does that mean? I still don't understand why some heads won't work with a roller block.
Originally Posted by JTSK
(Post 1597580879)
Here's a good video on iron SBC heads:
Thanks for the help guys.
