Weight of rear cradle ?
Hi,
(After posting this on tech parts, 11 views and no awnser, i copy this here) I have a seller of these parts at more than 5000 miles. I have a possibility of transport, but which is limited to 66lbs per package. The seller says he can not weigh them :-(, and i searched on the net, impossible to find the weight Maybe it's possible that everything is under 66lbs ? (or only the cradle, as i can ask to do two packages) Also do you have an idea of the weights? - rear cradle - leag - lower a arms - rear shocks Thanks |
Originally Posted by Steve@C56
(Post 1597580801)
Hi,
(After posting this on tech parts, 11 views and no awnser, i copy this here) I have a seller of these parts at more than 5000 miles. I have a possibility of transport, but which is limited to 66lbs per package. The seller says he can not weigh them :-(, and i searched on the net, impossible to find the weight Maybe it's possible that everything is under 66lbs ? (or only the cradle, as i can ask to do two packages) Also do you have an idea of the weights? - rear cradle - leag - lower a arms - rear shocks Thanks Try https://drive.google.com/file/d/0BxK...ew?usp=sharing |
Gotta bring this one back. Anyone know the weight of the rear cradle? I also searched all over and can't find it.
