c4 steer
87 Vette.when turning both sides,there is like a feeling of deadspot in steering..car wants to come back straight...rack as no leaks,no noise ands does it hot or cold
Originally Posted by biss
(Post 1597583453)
Good luck |
Originally Posted by ihatebarkingdogs
(Post 1597593013)
Too much (or a LOT) of caster can cause the heavy feel and desire to want to return to center. With the car stopped, turn the steering wheel side to side. Watch the hood in relationship to a wall or parked car in front of you. If you can SEE the hood rise at the ends of the turn, and drop as it comes across center, there is a lot of caster in the alignment. Some shops put a lot of caster in these cars in response to customer complaints of "wander". The result is a car that is not particularly pleasant to drive, although it tracks straight ahead. My personal experience is that 4 degrees is about the best compromise for 255/50's on 16" wheels. Other size tires may need more or less caster to get the best compromise bethween steering feel, and straight-line tracking.
I run 6 degrees caster on my 85, the steering is light no noticeable increased effort required. Was a horror driving on uneven poorly maintained highways, the car would dart / wander dangerously. The car has much improved stability requiring a light touch on steering wheel, compared to having to grip it tightly in case the car wanted to run off the road to follow a contour...... |
