1970 350/300 fuel requirements
If I run Gum-Out or some equivalent through the engine, followed by an oil change with Slick50; can I use unleaded premium without any problems?
Originally Posted by the70shark
(Post 1597592889)
I have a 350/300 with a 350/350 cam and have been running unleaded premium for the 30+ years i have owned it. No problems. I think you are talking about an oil flush and an oil change with additives. Not sure how this would help fuel issues. For the oil, I would use a high zinc content oil if you are running the stock flat tappet (or any flat tappet) cam. Off-the-shelf oils don't have the zinc content they once did and don't protect the cam as well as the older formulation oils. Are you having fuel issues?
(Post 1597592889)
Slick50
Originally Posted by dynra rockets
(Post 1597594668)
they still sell that stuff?
Originally Posted by Hammerhead Fred
(Post 1597593064)
Should run on unleaded premium without doing either of those two things.
Originally Posted by 2mnyvets
(Post 1597594060)
My question is why would you put Slick 50 in it? ask any rebuilder what that crap does to the inside of your block. use a quality motor oil suitable for flat tappet cam and leave the snake oil to salesmen
Originally Posted by fishslayer143
(Post 1597595455)
(Post 1597594060)
