93 6 Speed HotCam $6500 obo
Selling my 93 coupe, owned the car 7 years. I've done a lot to this car over the past 7 years and I'm very thankful for the help of you fellow forum members as I've owned this car. I'm an auto tech so I've had the ability to turn this cars life around. It's not perfect but a lot of major components have been replaced/repaired and it's a respectable daily driver. The car has 178k on it however heres an off the cuff list of replaced parts in no particular order in the last 3k miles: (I live in wisonsin/have a wife and child so it doesn't get driven much)
clutch/clutch fork heater core all 4 wheel bearings all u joints all fluids front upper control arm bushings all 4 shocks rear spring bolts(lowered 1 inch) with bushings rear sway bar link bushings rebuilt LT1w hot am 1.6rrs victor Reinz (thinnest) head gaskets opti plugs wires waterpump coil Icm air foil Corvette central catback exhaust (H-pipe) muffler delete and cats hollowed ( stock maifolds) targa seals (4) main front and rear and sides c5 z06 knock off 18x10 rear 17x9 front newish tires all around probably 7/32nds or more all 4 corners pioneer cd/aux/USB stereo multiple alignments floor mats all emissions deleted with proper pcm of north Carolina tune for the hot cam and deletion of emissions components headlight gears replaced A/C converted to R134a blows cold The car is fast, I have multiple low 13 timslips @107mph never dynoed but weight to trap speed would indicate 320ish whp or close 400fwhp 12 sec with drag radials( which I have but never used) will sell them with the car on matching rims. I'm sure I'm forgetting some stuff but if you have any questions feel free to ask. Some stuff I didn't get to: steering column is a little loose, I installed oversized pins but it didn't help much power lock actuators are weak, I've lubed them and freed them up but they will need to be replaced for normal functionality digital speedo display is faded (still readable) never bothered me trans grinds on hard high rpm shifts into second only, not noticable under any other circumstance only 6k+ fast up shifts Paint is ok probably 6 of 10 interior is ok probably 6.5 of 10 no tears (normal wear) the car is a respectable, reliable daily driver that needs someone with very little more time to spend on it to make it perfect or just enjoy it as it is. I'm located in wisonsin north of milwaukee in germantown. Figured id let the forum get the first crack at it before I post it on craigslist and have every kid in the neighborhood wanna drive it. thanks for your time, PM me if interested https://cimg5.ibsrv.net/gimg/www.cor...7d5ccafba3.jpg https://cimg9.ibsrv.net/gimg/www.cor...5e483066ac.jpg https://cimg7.ibsrv.net/gimg/www.cor...26dac472e0.jpg https://cimg2.ibsrv.net/gimg/www.cor...62c01d0886.jpg https://cimg0.ibsrv.net/gimg/www.cor...120c5a18c9.jpg |
What was the opti brand you used? How many times was it replaced? What are the options on your car? What were the injectors name you replacec?
It's a Delphi opti, was one of the first things I replaced been holding up well, Bosch 3 injectors from fuel injector connection (blue). The car is an FE1 base model with leather only has power drivers seat.
Bumpski
Bump |
