Choke coil 69' 350 L46
Before I run up to the local napa, I thought I would try here first. I need a could used or new choke coil for my 69 350.
Not sure what I have is any good, somehow it got bent up where the rod attaches and not sure it will work as designed. Thanks, Joe |
If it's the same as a 70 l48 I'll give you one
Wow. Thanks. My research shows it is the same , at least for 68-70 small blocks.
I will send you a pm. joe |
