Cast blast paint for exhaust manifolds
Did a forum search for what paint would look good on my drive shaft and half shafts, and Seymour Cast Blast seems to get a lot of votes. I'll get some.
Then, as a separate project, I'm looking at their high temp stuff which I could put on the exhaust manifolds. But they say it needs to bake at 400 degrees for at least 2 hours. I have a patient, understanding wife, but I'm not THAT stupid! :hide: What do you guys do for stuff like that? |
POR15 exhaust paint
Hi-Temp Cast Blast is the way to go. I've used it on at least a dozen cars with no complaints. I just let the heat from firing up the engine cure it. Here's a pic of my 65 BB after curing the exhaust. The manifolds on my 60, that I did 30+ years ago with Cast Blast, still look just like this.https://cimg7.ibsrv.net/gimg/www.cor...3262b12dc8.jpg
I should add I'm a long way from firing the engine, have not even torn it down yet. Trying to get ahead of the game by doing the manifolds and setting them on a shelf. I guess finding some hot rod guy with a kitchen oven in the shop is the best option. Or maybe browse CL for one of my own but that seems like overkill for something I won't do very often.
Por15 Manifold grey for me also.
Originally Posted by 67's
(Post 1597698898)
All high temp paints should be control heat cured prior to using in anger. They will last significantly longer. if you have the room, I bought an electric oven from Craig’s list for $25 because only one of the stove burners worked. He even delivered it to my house. I use the oven to cure powder coating, high temp paint, and to clean parts (it’s amazing how well ez off oven cleaner works on greasy parts when you have a little heat). Prior to that I had a toaster oven I got for a few bucks at a yard sale. You might luck out and find a toaster oven big enough for your manifolds. They work great for curing high temp paint, just make sure you preheat them first. |
I used Seymour Cast Blast, and cured them in the bbq grill, with the outer burners on only, and the manifolds in the center. I figured the thermometer in the hood was close enough. I think they came out looking pretty good, but I haven't run them yet.
https://cimg5.ibsrv.net/gimg/www.cor...0fc7c636de.jpg |
Originally Posted by Muttley
(Post 1597699612)
Originally Posted by Frankie the Fink
(Post 1597699633)
And how did you prep those ?
Here are some options side by side for you that I just happen to have on hand, but I am not going for judging or anything....https://cimg4.ibsrv.net/gimg/www.cor...3e168810af.jpg
Wow, some nice looking parts there! :eek:
Excellent comp pic !!
Eastwood's high temp paint works well and lasts.
Yes
Originally Posted by C.T.
(Post 1597701724)
Originally Posted by Factoid
(Post 1597699292)
Don- use the cast blast benton |
Originally Posted by Railroadman
(Post 1597704745)
You are talking about pre-heating the oven, not the work product, correct?
cast iron high temp gray
(Post 1597698443)
Then, as a separate project, I'm looking at their high temp stuff which I could put on the exhaust manifolds. But they say it needs to bake at 400 degrees for at least 2 hours. I have a patient, understanding wife, but I'm not THAT stupid! :hide: What do you guys do for stuff like that? https://cimg3.ibsrv.net/gimg/www.cor...ee3f776ad7.jpg I prefer the brush on for irregular objects https://cimg4.ibsrv.net/gimg/www.cor...412f4323b6.jpg Sandblasted first I just did the exhaust for my 66 bb and was pleased with the way they turned out. I have used this before with good results. I like the brush on so you can get in tight places without runs. |
And
Originally Posted by Vette5311
(Post 1597705788)
