tuning for auto transmission
There's one thing I want my vette to do differently. When you're cruising in 6th and want to down shift to say 3rd; you pop it into sport mode and hit the paddle shifter 3 times... and wait as it carefully goes through the gears. This often means the car down shifts while I'm in a turn instead of just before the turn. Is this something that can be changed with a tune? Can the car just jump to whatever gear you tell it to?
2007 base. |
Yes, a tuner can speed up the gear change for you
No. Start downshifting a little sooner, it cannot jump gears.
Also a tuner can not make the car shift faster. He can make it shift harder. |
Originally Posted by zrracer
(Post 1597763343)
(Post 1597763343)
Originally Posted by subfloor@centurytrans
(Post 1597763354)
Uh, yeah he can. Shift times are one of the easiest things to modify in the trans tune.
Subfloor is a tuner and he is close to you.
(Post 1597763354)
Shift speed can indeed be adjusted in the tune.
To clarify, this is the amount of time it takes to perform the actual shift, has nothing to do with the delay from when you click the paddle to when the trans 'does something' Is holding the downshift paddle not an option to downshift to the lowest available gear in these cars? In my charger I can simply hold the downshift paddle for a second and it automatically drops to the lowest/safe gear based on speed. Roll race special :) I don't recall if my T43 equipped Caddy had the same option or not... |
Yes, if the left (-) minus paddle is held down briefly, the transmission will downshift to the lowest gear possible for the vehicle speed. And if the paddle continues to be held down as the vehicle slows, downshifts will continue to occur as vehicle speed allows.
Originally Posted by jim2092
(Post 1597820555)
Typed right out of the owners manual.
(Post 1597826251)
My apologies. That is a C7 feature.
(Post 1597834888)
Can Diablo tune change rpm shift points?
Originally Posted by Mike@DiabloSport
(Post 1597810527)
Yes, you can adjust the WOT shift RPM on that application. Id suggest bumping the limiter a bit first.
Thanks |
WOT engine cuts out
(Post 1597886238)
Thanks |
Is this a stock car?
Are you asking about lowering the shift points to keep it from hitting the limiter? If the shift points and limiters are all stock, and it hits the limiter in D on any shift, there's more likely a possible trans issue that needs to be addressed here... |
Mike , I think he is waiting to long to flip the paddle causing the car to bang the revlimiter because of the delay time
While running a road course I would just anticipate the delay and bump the paddle a little sooner when I installed my Diablo Lew Tune ...and running the 1/4 mile I just left the shifter in automatic sport and let the trans do the shifting ... it shifted right on the redline every time Dave |
