Excess oil consumption issue
Had my 2015 base C7 for a little over 3 yrs and only have 6300 miles on it. I get the oil changed every April when the weather changes. When I had my last oil change in April, I checked the dipstick and it was at the upper hash mark-OK. However just for yucks yesterday I checked my dipstick (first time outside of checking after an oil change) and noticed the oil level was very near the bottom hash mark. I have only driven the car about 900 miles since April and am concerned about the oil consumption. I do not track my car, but I do like to give it occasional spurts of hard acceleration when I do drive it. Any thoughts on this. Thanks
Wow, I have had just one car with very high oil consumption and it's not fun. I do know that the level varies a lot depending upon how long you wait to measure it. I would suggest topping it off and then actually measuring at an exact time after shutting off the engine to try to get a more precise record. You might find you are really OK. Good luck!
Did you check your oil in April after the oil change? Who ever changed your oil may have not added the correct amount. You can check your oil in the morning before you start your car and get an accurate reading..
Dry sump or wet sump? Same temperature when both checks were made? I'd change the oil again but use one of the 40 weights... either the "approved" 0W-40 Mobil 1 ESP or one of the 5W-40 offerings. Run that for awhile and see how she does.
Originally Posted by raylo
(Post 1597751479)
base=wet sump. Temps were different as one was in April and the other was in August. I will top off with Mobil 1 5-30 since it was the same oil always used and put in by the factory in 2015. |
Originally Posted by John Micheal Henry
(Post 1597751433)
Originally Posted by JonMN
(Post 1597751307)
Originally Posted by Corgidog1
(Post 1597751589)
Thanks. Waited 4+ months.
(Post 1597751986)
OK, I was thinking minutes, not months. When car is hot, wait a specific number of minutes and measure level. Drive 1000 miles and repeat. Oil measurement is very dependent upon engine temp. [I did this over and over and ended up with a new engine for my 911 as consumption exceeded a Qt per 500 miles.]
(Post 1597751142)
He asked for info about oil, nothing about "do YOU approve of his driving habits". Just saying, wait 5-10 mins. after reading before you post. I know everyone on Facebook/Twitter, etc. can't wait to Flame everyone else but this is a HELP forum with folks asking for real advice. If I have no knowledge or input to the question then I simply observe to see if something comes up that may help me also. Really not trying to pick a fight but sometimes we get a "bit mean" on here.:cheers:
I am more of the opinion that you get a more consistent reading if you measure oil level after the car has sat over night and cooled off. Worrying about how much the oil level changes with the temperature goes away. With a wet sump engine check the oil the first thing in the morning after the engine has been off for 8 to 10 hours.
Bill |
(Post 1597751142)
If there is "excessive oil consumption," after the break-in period, I would say that taking too long to put on 1500-2000 miles may not be such a good thing. I don't know how long it took you to put the first 1500 mi on the car, but that is probably the most important 1500 miles the car will ever have, and doing it in a matter of weeks, or days,to set rings to pistons (so they learn to love each other), rather than months (or more) does the engine a favor in the long run. At this point check and add oil as necessary. Cars have been consuming oil for decades. As long as you stay on top of it, no real harm, IMO. |
(Post 1597751142)
If you actually burned a quart in 900 miles you’d see that as a smoky exhaust. I assume there are no leaks. Is there oil on the filter? |
Originally Posted by CP
(Post 1597754815)
Why do you even have this car? 2100 miles a year??? Who ya saving it for, the next owner?
(Post 1597754815)
(Post 1597756933)
Bill |
Originally Posted by JerryU
(Post 1597757185)
If you went from near the top hatched mark on the dip stick to the bottom mark, that is ~1 quart. Owner’s Manual states when at the Min mark add a quart. That is about 1 inch on a dry sump assume about the same on a wet sump. If you actually burned a quart in 900 miles you’d see that as a smoky exhaust. I assume there are no leaks. Is there oil on the filter? |
Originally Posted by owc6
(Post 1597757024)
With the few numbers of miles you put on your car each year, I would say you do not have to worry about excessive oil consumption during your ownership in the grander scheme of things.
Something is telling me there is nothing wrong with your car and it doesn't burn oil.
I would read the owners manual about the checking procedure and then be vigilant about checking it. I'm betting you find out everything is fine. |
