-   C3 Tech/Performance (https://www.corvetteforum.com/forums/c3-tech-performance-3/)
-   -   Rear brake line fitting (https://www.corvetteforum.com/forums/c3-tech-performance/4174711-rear-brake-line-fitting.html)
73TexasVette 08-09-2018 11:51 PM
As the title suggests I'm trying to find the the thread of the fitting that connects to the rear flex line(Highlighted in the pic below) so I can find a plug at the autoparts store to keep everything sealed up while I'm replacing my rear trailing arms. Thanks for any help!
https://cimg7.ibsrv.net/gimg/www.cor...d26c1c4fb0.gif
Bikespace 08-10-2018 12:05 AM
If you want ANY help, I used a pair of cheap vise grip clones to clamp off the two rubber hoses. My trailing arms are still out, but if you are going to replace the rubber hoses anyway, this might be an option to consider.
terrys6t8roadster 08-10-2018 04:46 AM
A brake line, cut and fold over the line, hammer fold tight and install. T
revitup 08-10-2018 07:50 AM
All different size rubber plugs are sold at Ace Hardware
DUB 08-10-2018 09:29 AM
I AGREE.
Even though I have the blue cap plugs that can seal this port off. Getting a brake line and doing it as what has been suggested is the fastest way to get it done.
I ALSO agree with clamping off the rubber hos which I do IF I am replacing the hose with a new one. I NEVER EVER clamp off the hose if it has age on it and I am NOT going to replace it for any reason due to causing for possible problems in that hose later on....even though they make tools to safely clamp of the hose. I just do not do it and will use my plug instead....and I often times even put a new hose on due to being so inexpensive.
DUB
sambrand 08-10-2018 01:52 PM
heh ive always used plastic bags cut and triple folded then taped to protect the threads and prevent dirt getting in.
73TexasVette 08-11-2018 12:53 AM
Originally Posted by DUB (Post 1597765159)
I AGREE.
DUB
I've thought about clamping the rear flex line but I just replaced it last month so I was hoping to not damage it and I don't have any spare metal lines to make into a plug. But it's looking like clamping it may just be the easiest option. Thanks for the ideas!
kansas123 08-11-2018 09:40 AM
When I replaced my Master Cylinder a couple of years ago, I bought some sort of kit from O'Reilly's that had lots of different sized plastic gizmos that had male or female threads and small rubber hoses for bleeding. Many good uses for these especially when dealing with brakes and brake lines.
DUB 08-11-2018 06:03 PM
Going to a parts house and buying a metal brake line about a foot long costs basically nothing at all to make the plugs you need.
DUB
mortgageguy 08-11-2018 10:18 PM
Golf tees.
keithl1967 08-11-2018 11:13 PM
It is a 3/8, 24 pitch
Available at autozone:
BLF-60C solid brass Male plug...$2.99.
https://www.autozone.com/brakes-and-..._0_92953_92958
Bought two today--one to seal off the brake line and one to seal off the Caliper while I continue to work...worked perfectly
gjohnson 08-12-2018 09:46 AM
McGyver 101...I used a plugged rubber hose that I screwed in.
73TexasVette 08-12-2018 05:32 PM
Thank you!! Thats exactly what I was looking for. I'd forgotten I need to seal the calipers off as well to keep them trash free. Looks like I'll be headed to autozone tonight.
scottjamison 08-13-2018 12:12 PM
By the way, if you haven't done it before, this guy's videos helped me a lot.
His dental floss trick probably saved me a 1/2 hour and a lot of cussing!
He has a 2 part series for removal and for installation.
keithl1967 08-13-2018 01:54 PM
Great video—watched a few times as I was prepping for the job. His shock mount cane out way easier than I am experiencing!
73TexasVette 08-13-2018 10:33 PM
Video
Thanks for the tip! I've seen those a few times and they have been very helpful so far. I'm jealous of how easily his shims came out. I've been soaking mine for a week and can't get them to budge.
Bikespace 08-13-2018 11:16 PM
That's a great video. I'm glad the closed captioning specified "a set of ole tongs".
Dental floss is the key to many Corvette tasks, and to preventing gum disease.
Easy Mike 08-14-2018 11:26 AM
Originally Posted by mortgageguy (Post 1597775027)
...Golf tees....
:yesnod: Works for me.
