ATI super damper systems in stock and on sale at Juiced Motorsports
ATI Performance Products are the name in Harmonic Dampers. They eliminate tensional crankshaft vibrations, Exceed SFI 18.1 specs, black zinc chromate finished, tunable, rebuild able, extremely efficient at all rpm and have laser engraved timing marks. The C7 Dry Sump Super damper will allow you to use over drive supercharger pullies to add easy boost. This is the best way to add boost to your C7 Z06. Order from Juiced Motorsports and get the best prices, free shipping and fast delivery. We have these systems in stock and ready to ship. https://cimg2.ibsrv.net/gimg/www.cor...7db3f79509.png ATI 917315 - LT4 Super Damper (crank hub) ATI 96163-5 - 5% overdrive pulley ATI 96163-10 - 10% overdrive pulley ATI 96163-15 - 15% overdrive pulley ATI SK1040-B5 - 20% overdrive pulley |
Big power and a quality balancer
In stock and ready to ship or install. Order as a stand alone mod or pm/call about our Z06 stage 1 or stage 2 bolt on package. If you really want to max out your Z06 we can go stage 3.
Call for package deals. We can turn your Z06 into a killer
Pull some big numbers
In stock and ready to ship.
PM or call for our big power package deals
Best pricing around on ATI balancers. Big power from a lower pulley swap.
We can install and dyno any set up you want. Let's start a build around this IW balancer
Major power gains with a lower pulley upgrade
Do you have this for the LT1 engine? |
PM sent
ATI systems in stock. Let's mod that C7Z
Order online or call us for an install. Package deals including these coming soon.
Ati
Will this outer fit ATI LS 2/3 balancer. I think last 3 numbers are 278. |
The outer supercharger rings are designed for this ATI balancer 917315
In stock, order online or schedule your install.
Order online or call to have yours installed.
Your Z06 scoots no doubt. Add some more boost and it will be a legend!
We have them in stock. Order online or let us install one for you
