Swapping from 17/18 OEM Street to 18/18 Autocross
I'm looking to run my OEM 17/18 wheels with street tires (265/295) in my stock '02Z for street use, and then swapping to a 18x9.5/18x10.5 setup with Rival-S (275/315) or RE-71r (265/285) for A-street autocross. Car isn't lowered. Is there anything wrong with this that I'm missing? Does the suspension need to be altered? Is there a better way to go about running a good set of 190+TW autocross tires within the A-street rules (+/- 1" diameter rim, 9.5" rim up front, 10.5" rim rear)?
The only thing you're missing is a 19x10.5" rear wheel to run the 305 RE-71R. The current AS setups are either the 275/315 Rival S or 275/305 RE-71R. So you're close, but go with the extra tire.
Originally Posted by 907Y02Z
(Post 1597980696)
OT they have autox in Alaska? My daughter & son-in-law lived/worked there a while. I have visited, great place (in the summer). :) |
(Post 1597984263)
mattastick, thanks for your response. The reason I was thinking 18/18 for autocross was that I'd read posts from members that said the car was better balanced, and that it helped cure the front end understeer 'plowing'. I've been digging up posts on 18/18 vs 18/19 for a bit, some members say the best reason to go 18/18 is for true square setups so you can rotate all four tires (which I obviously can't do for A-street). Has anyone tried 18/19 in Autocross that can compare it to the handling of a square setup? If I go 18/18, do I need to tune the chassis in any way to adjust for the difference in rake? However, looking at tire prices makes me think I should just run a true 18/18 square setup for rotation purposes and forget A-Street... So many options. If you want to forget about AS, get an extra pair of 18x10.5 rears, run 315 square Rival S' and run in CAM-S. The plus side here is that you can mod your car in whatever way you desire, and there are basically no limits. |
Originally Posted by mattastick
(Post 1597984407)
The fast AS guys all run a 275 front tire, regardless of their chosen brand. This helps add front grip. The rear tire is a choice between the shorter BFG, which some people like, or the extra gearing and steering precision of the RE-71R. If you're running AS, these are your best options to be competitive. Anything else will be leaving performance on the table, IMO. Ignore what most people do here, and look at/talk to the folks that are competitive at National events. Most people here are either slow, or never leave their local lots (or both), though looking at my piss poor Nationals experience, I definitely fit in the former group.
If you want to forget about AS, get an extra pair of 18x10.5 rears, run 315 square Rival S' and run in CAM-S. The plus side here is that you can mod your car in whatever way you desire, and there are basically no limits. Froggy: Yeah they do have AutoX in the summer! SCCA runs 14 events, PCA runs 8. They're generally low speed/technical courses. Not looking forward to having to put the car away for the winter... |
(Post 1597981169)
I ran 285/305 re-71 in A street with 18/19 front/rear aftermarket wheels...rules legal.
Why 275 up front? With max camber (I think -2.7ish) and lowish pressure (26-28 hot typically) I used every bit of the front 285s. They fit just fine up front. If anything the 305s look more oversized to the wheel than the fronts as I struggle to get to the wear marker. Still running this in cam until I wear out the fronts and switch to the cam rival setup. |
Originally Posted by DudeWithAVette
(Post 1598008658)
Great call-out.
I think I reset my ride height and rake with the new wheels/tires on but now you've got me doubting myself. I've never had a problem with active handling or abs using this setup for autox and hpde for anyone who is curious. |
(Post 1598008816)
Great call-out.
I think I reset my ride height and rake with the new wheels/tires on but now you've got me doubting myself. |
18x10.5 square
Originally Posted by smitty2919
(Post 1598028146)
18x10.5 square
Can't do a lot of good/typical stuff in A Street....no CAI, no LT's, no dyno tune, no smaller steering wheel.
A-Street won't be the class for me. CAM-S HERE I COME!:willy: |
(Post 1598042183)
Originally Posted by MatthewMiller
(Post 1598042838)
I'm there now. But be warned, if you run 10.5" square in CAM-S, you'll be in the narrow-wheels club!
(Post 1598042895)
True, BUT 315/30/18 Rival-S are getting plentiful and cheap at the end of each season. The most common 18" tire. Or the 335/30/18
Yep. It's super easy and cheap to go 18x10.5 C5Z rear wheels all around and 315/30/18.
Outside of that you are buying Forgestar wheels with capability of custom offsets for 18x11 or 18x12. And beyond that is Forgeline.... So yea, I'll stick with the easy button :) I don't have the wallet to play THAT hard. |
(Post 1597980696)
