Best tuner for an LS3 A6
I'm returning to the forum after being gone for a couple of years.
When I was here before I had an '05 Z51 M6 and I put an intake, Pipe, and axle back exhaust on it with a Diablo Sport tune by Lew about 5 years ago. I was pretty happy with the results and I now have a '10 base A6, 4LT. I'm going to do a similar setup on this one, possibly with long tube headers. I'm wondering how much has changed in the tuner world at this time. Does anyone have a similar setup with the A6 that they are happy with and could recommend some direction for a tuner to help firm up the shifts and have the A/F ratio adjustments available when I swap out parts in the next few months? Thanks in advance Trey |
I had Diablo Lew do the tune on my "bolt on" 2011 C6 along with his transmission tune . I was very happy with the results ....
Dave |
Originally Posted by Dcasole
(Post 1597987675)
Dave 10-4 thanks. Did you use one of the canned tunes that comes with it first or go straight with one of his tunes? |
Originally Posted by C6Tally
(Post 1597990899)
then did the CAI , headers , and fast 102 ... logged the car and then enlisted Lew . Loaded the new custome tune , log ....a wide open run , sent to Lew again ... you can rinse and repeat as many times as u need to . Just as good as a street tune but done remotely Dave |
(Post 1597991002)
For a header tune a Diablo is fine , I started with the 93 tune and firm shift tune , turn off Torque Managemnt as it limits your power to 380 HP in 1st and 2nd gear ..
then did the CAI , headers , and fast 102 ... logged the car and then enlisted Lew . Loaded the new custome tune , log ....a wide open run , sent to Lew again ... you can rinse and repeat as many times as u need to . Just as good as a street tune but done remotely Dave I did the data logging tune with Lew on my last one but it was an M6. I think I'll wait until I do the header addition before I bring him in on this one as well. |
(Post 1597991104)
Gotcha. How was the 93 & firm shift tune in yours?
I did the data logging tune with Lew on my last one but it was an M6. I think I'll wait until I do the header addition before I bring him in on this one as well. this is a gain that you can feel ... Dave |
(Post 1597991321)
The motor responded well to the 93 tune but the biggest gain cam from shutting off torque management....
this is a gain that you can feel ... Dave That's the info I was looking for. This one feels like it has a little vibration from about 2500-4500 rpms and I was wondering if it had something to do with the traction control / torque management. Thanks Dave Trey |
Corvette tuner in Tampa
(Post 1597982117)
I was pretty happy with the results and I now have a '10 base A6, 4LT. I'm going to do a similar setup on this one, possibly with long tube headers. I'm wondering how much has changed in the tuner world at this time. Thanks in advance Trey How Im Different and make the money is I make changes to the torque management system. I found this way the best. The more throttle you apply, the firmer the shift will because. In normal traffic, the transmission shifts a little shorter than stock. Go spirited driving and get ready to chirp a gear. I have 90% automatic clients because thats who I Taylor the transmission settings for. You can make it custom for each owner using the D mode and M mode Lots of tables to change, but that what your paying me to do and I do it right |
Highly satisfied with the tune done for me by Tampa Tuning. Phil is highly skilled and is very thorough in his work. Check out https://shop.tampatuning.com/home.html to learn more then get in touch with Phil. Good luck! |
