Whats the ideal rear wheel/drag radial size for racing?
I have a base model with z51 brakes, will 17" (2006) gumby wheels fit on the rear and what is the ideal tire hieght, OD for drag racing? I want to not have active handling problems. Probably the wrong section but you guys know what your doing, thanks!
Power level? Track prep? Type of racing? 1/8th, 1/4, 1/2? Street use too or track only?
There is no blanket best, it all depends on application and what works for you. For strictly drag racing a 6 speed manual car, a bias ply 15 in the narrowest lightest tire that will still hook based on the track, will be the best. |
Smallest tire that hooks. Unless you make a good chunk of power I would stay with a 26” like a hoosier, MT, Toyo DR. |
Power level is 750 wheel. Track is local 1/8 mile Irwindale Ca. Im looking to buy rear rims and tires for the track but would have to drive to and from. I dont want to change wheels there. I'd like to do 1/4 mile too, thats a longer drive, so 1/8 mostly. My car is a manual trans if that matters. Track is prepped. I'll look at 26" or close. I had Mickey Thompsons before but that was on a bigger wheel. I was really happy with those. My main concern was if 17s would fit over z51 brakes and wheel diameter. Thanks for your replies.
15" conversion is best. I use the M&H 325/45/17 or 18s work great. Just won a cash day event, beating many trailered race cars on slicks.
this
Originally Posted by c6 monkey
(Post 1597983008)
This is exacly what I wanted to hear, thanks Iroc. I have summit on speed dial
what air pressure you running the 17s MH? i still have problems getting it to hook at 23 psi on a half ass prep above 2k rpms. (900rwhp)
