Originally Posted by stevieturbo
(Post 1598065794)
Same Chinese intake everyone is selling, Holley included.
They claim 1/8" thick....I'd dispute that having cut and re-welded my own to make it fit my own car. Quality is poor, and the bloody horrible sound that resonates due to the thin metal is another aspect. Some people have burst them too. But I'm prepared to tolerate it for a while, as it does look good and it was cheap. Whether it does or doesnt improve low/top...TBH I havent really noticed any difference from the previous BBK I had. Certainly nothing negative to report in terms of performance. |
Originally Posted by Under-Pressure
(Post 1598066308)
Don't know if it's been said yet, but the BTR manifold doesn't fit on the c5. Brian told me he fit it on his c5 and it needs trimming to fit.
(Post 1598066308)
They also released the pressure very slowly....and for this application that does not happen. Pressure will rise/fall thru vacuum very fast with throttle movements etc and one cycle does not cover the fatigue aspect. Now perhaps the ICT is not the same Chinese intake everyone else sells...although it does look like it. Others have burst similar intakes. I had to cut the front off mine to lower the angle of the TB flange for it to fit my application, and the metal is not 1/8" as claimed. I didnt measure, but I do know that 1/8th sheet is pretty thick in your hand. At a guess I'd say closer to 2.5mm or so vs 3.125mm. And then there is this....and I only came across it after I already had my Holley intake. Mine makes a similar irritating noise !! Cheap thin metal. Inside the car it's not so much of an issue, but when I'm outside or the hood is open and engine running it is bloody annoying. https://ls1tech.com/forums/generatio...noise-wtf.html And then there were the fuel rails....where the one end of each was not machined correctly for the o-ring fittings that were supplied....and the o-ring would get destroyed on tightening. Using a 1.5mm cross section o-ring instead of the "correct" 2.0mm CS did resolve that though..... Port alignment with my 225TFS cathedrals was bloody terrible too. I do have a lot of bad to say about my Holley intake, largely quality related. But I do still have it on my car after remedying things as best I could. It looks like a much more expensive intake and looks good on the motor. It would also be nice to see these intakes run the correctly angled injector bosses too though instead of the straight down they do. Straight down is not correctly angled towards the valve. A minor point perhaps. But again....it was cheap. I liked that bit lol. TBH I wish I'd bought a ProFlo although I'm damn sure it wouldnt have fitted height wise, another reason to try the Holley first to get an accurate picture of what room I had. |
And it still goes to show...if you mostly operate below 6k....factory style intakes always win ! Still some decent gains above 6k though
Facebook Post |
So, below 5k RPM it's down almost 100HP to the LS6? Yikes.
Interesting that the BTR with just a smaller throttle body made more HP below 5800 or so than it did with a 102. What's up with that? |
Only idiots oversize their TB....
Really, a better test would be with the typical 92mm as per most DBW vehicles. But larger blades can affect airflow, slow down airflow etc etc which will have a negative effect. But it still goes to show how bloody good the factory style intakes are. LS engines clearly love those long runners in the operating range most people do use them at. Really, any "new" intake would need a compromise of those long runners and with a large plenum. I'd say around 8-9" long runners would be nice to see on a test...AND with a good angle where the pair with the head. That's another very bad aspect about the likes of the Holley sheet metal, and I'd have to assume ProFlo and HiRam too. Given the shape of the ports on an LS and the angle of entry to them, a runner with a similarly shallow entry would make far more sense than the downwards runs of the aftermarket intakes |
Of all the intakes around so far...I liked the idea of this one James/G1Pro drew up. Plus he was suggesting he could offer various bolt on runner lengths. Not sure overall what sort of height it could be though.
Originally Posted by G1Pro
(Post 1596866446)
Haven't posted in a moment, I'm horrible at keeping up with forums when all I'm doing is designing and burning welds out all day hahah.
Got some ultimate new things coming out. "mod ram" manifold uses a shorty style sheet metal modular design "holley hi ram plenum flanged" plenum bottom. The ports inside or drilled and tapped to accept interchangable runners to tune your setup 100% perfect. You can pull your plenum top, change runner lengths all on the dyno. https://cimg6.ibsrv.net/gimg/www.cor...266bb8f790.png https://cimg7.ibsrv.net/gimg/www.cor...9c9eeb1227.png https://cimg8.ibsrv.net/gimg/www.cor...2d69a0182c.png https://cimg9.ibsrv.net/gimg/www.cor...fac0c87691.png https://cimg0.ibsrv.net/gimg/www.cor...34539bc9fb.png https://cimg1.ibsrv.net/gimg/www.cor...ea4805169d.png https://cimg2.ibsrv.net/gimg/www.cor...8ec0c325fa.png https://cimg5.ibsrv.net/gimg/www.cor...1019605205.png https://cimg6.ibsrv.net/gimg/www.cor...c25ab70734.png https://cimg7.ibsrv.net/gimg/www.cor...00263285bf.png https://cimg4.ibsrv.net/gimg/www.cor...52859a407c.png https://cimg8.ibsrv.net/gimg/www.cor...71ed012834.png this means you can use a holley top, or buy one of mine. This also means if you happen to already have a air water core from someone else you can drop the overall height of your build and have a tunable runner. virtually unlimited options here. coming to cath, ls3, ls7 standard and tall deck. LTx as well. |
I'm about as far from an engineer as it gets, but why doesn't someone just copy the factory ls manifold design and make it out of cast aluminum?
(Post 1598069074)
...LS engines clearly love those long runners in the operating range most people do use them at. Really, any "new" intake would need a compromise of those long runners and with a large plenum. I'd say around 8-9" long runners would be nice to see on a test...AND with a good angle where the pair with the head...Given the shape of the ports on an LS and the angle of entry to them, a runner with a similarly shallow entry would make far more sense than the downwards runs of the aftermarket intakes
(Post 1598069106)
Plastic forming etc will give more freedom in terms of shape and manufacture vs cast alloy. |
Originally Posted by TastyBacon
(Post 1598069136)
Sounds like you're describing something like the Edelbrock cross-ram.
Keep it simple....8-9" runners, and a large single plenum. |
BBK intake....very similar to the LS6 inside, and the runners hit the head at a nice straight angle too...again as per OEM.
https://i.postimg.cc/MGWJn5fp/IMAG0853_Large.jpg https://i.postimg.cc/ZY9nYYhD/IMAG0856_Large.jpg |
Although there'd be room for some porting and smoothing with the BBK, as supplied it is fairly rough. Still a decent sized plenum underneath the runners though.
But the runner openings are fairly shrouded. LS6 factory might be better in that respect |
(Post 1598069141)
Like the already mentioned BBK and Weiand did ?
(Post 1598069222)
Correct. Except I have square port heads and they dont make them for it, at least yet
LS3 intake has proven itself so well already, it'd be doubtful a similar cast alloy version could improve on it, simply from manufacturing limitations. |
(Post 1598069246)
Probably never will if not done by now.
(Post 1598068910)
https://www.facebook.com/BrianTooley...type=3&theater This intake is garbage. All that hype for nothing. All the BTR fan boys will buy it and go slower. It just gets its ass kicked under 6k. If your drag racing to 8k its a good intake. |
Originally Posted by Podium
(Post 1598074198)
It is only one test they've released, and yes it is certainly disappointing. Time will tell if they can produce a better combo. Although even shifting at 7500rpm, should see you above 6k most of the time so still somewhere with gains..and boost proof you're after. A Nice billet CNC'd lid without the logo would look a bit better too, although visually it is quiet nice as it is. Again...the bottom line is it needs longer runners. Or perhaps smaller port runners at current length to increase airspeed in the ports. |
