What goes on in a differential
Kind of an interesting video from Gale Banks that I ran across on the Mopar B-Bodies forum. Apparently more goes into configuring a differential housing and cover than I knew.
Thank you for sharing this.
Excellent video from Mr Banks. I really like the plastic cover. Diff's are in fact a large gear pump. The 63-79 vette housing was squared off so it would be interesting to see a vette diff with plastic cover. The action is the same though. While the vette has no side tubes the axle bearings are lubed.
Here is a vette housing with the parts removed and you can clearly see the upper oil passage and the return on the lower end. http://img.photobucket.com/albums/v2...psey13elpf.jpg |
A clear cover would be of little use. Once things get spinning the fluid is slung everywhere obstructing view.
Originally Posted by DansYellow66
(Post 1598027386)
https://www.youtube.com/watch?v=9-yG3D3JBRs |
always great to learn, tnx for posting:thumbs:
Originally Posted by GTR1999
(Post 1598027804)
(Post 1598029162)
Thanks - good photo. Those of us who haven't ventured into a differential tear down have probably never seen or were aware of that passage feature.
Great, informative video....Thanks:)
Some of those videos are enlightening, I am often asked why the early self-adjusting brakes don't "over adjust" themselves - I respond with this, there are some superb videos on rebuilding Muncies and trailing arms too:
