Accel Pro Ram Single Plane EFI Intake Manifold
….. Sold … Sold … Single Plane EFI Intake Manifold with Fuel Rails … port matched to 1206 gasket size … $350 shipped to the lower 48 …..
….. See pics in next post … site is being stupid tonight ! ….. |
Intake
Originally Posted by C409
(Post 1598044654)
https://cimg0.ibsrv.net/gimg/www.cor...30434e554f.jpg
https://cimg1.ibsrv.net/gimg/www.cor...c77d2095b4.jpg |
..... This intake will bolt up to all stock iron Gen 1 sbc heads from the beginning of small blocks until '87 (+or- a year) and all factory aluminum heads as used on L98 C4 Corvettes … it will also fit almost every aftermarket head intended for Gen 1 small blocks … particularly intended for those with 1206 sized intake ports … I'm not exactly sure if that adequately answers your question because I have never seen D-ports on the intake side of any normal production small block Chevy cylinder heads …..
(Post 1598052470)
Interesting piece. What kind of plenum and throttle body would you use on that to keep it under the C4 hood?
Originally Posted by BV85
(Post 1598056991)
The chevy FAST BURN HEADS only use 4 bolts per side in stead of 6. Can this intake be bolted to this type of VORTEC CHEVY HEADS. TIA
Originally Posted by slow-vette
(Post 1598057417)
https://cimg8.ibsrv.net/gimg/www.cor...f6ff37dcfc.jpg |
..... I ran this intake for about 2 years on my '87 … also ran an ad for the whole set-up on this site to the tune of over 4,000 views … check it out ! …..
….. Still Available ! …..
….. Still Available ! … Beat the Holiday Rush ! …..
Quick FYI, fastburns have the normal sbc intake bolt pattern and the vortec intake pattern. However, the intake ports are taller than a normal sbc so that needs checked.
Pm sent
Did you ever sell this and did you ever sell the custom plenum that you used on this?
Originally Posted by tuneportbeast
(Post 1600935250)
….. Gone ! ….. |
