So my torque converter just blew up..
I swear I have the worse car luck lately.. The LT4 is up on jack stands now as I try and figure out why its been misfiring.. then, as luck would have it, on my way home from work driving the LT1 and the fn torque converter literally blew up 3 blocks from home.. I just limped into the garage.. Both vettes are now down. :sad:
A Precision Industries Vigilante converter will never blow up. Full throttle lockup in third gear and the converter hits like a gear change. Probably a 1000 10 second runs on the converter.
Originally Posted by AgentEran
(Post 1598113520)
I was at a stop sign, when I went to accelerate I hear a loud explosion.. like Boom.. not unlike a firework. Then I hear metal on metal.. sounds like the stator or turbine went boom and disintegrated.. I can only hope the fallout didn't ruin the tranny.
I have no idea who made it, I assume it's stock.. will find out tho |
(Post 1598115046)
Originally Posted by aklim
(Post 1598115074)
Time for a totally rebuilt trans
(Post 1598115074)
NFW would I trust that the trans itself is still good or that there were no metal pieces that went into the line and into the trans.
(Post 1598115108)
:sad: At this rate im never going to get to paint Ol Blackie..
(Post 1598115115)
And I know your 100% right here too.. (sigh)
Damn dude I am sorry about that:(
Definitely do a somewhat built trans on the car. Have you looked at the fluid to see if metal is in it? |
Originally Posted by 1993C4LT1
(Post 1598115445)
I think you need get it on jack stands and try to determine what failed. I never heard metalic noise from a failed converter. Whine as engine was revving and car was creeping. 700s can have the pump bushing can fail. Broken flexplate could pop then make a sh1t load of noise as car creeped along. The hub portion clashing with the part bolted to converter.
(Post 1598115445)
Definitely do a somewhat built trans on the car. Have you looked at the fluid to see if metal is in it? It just seems like every time it looks like a good time to paint my black car something happens and I spend the money somewhere else.. hard to justify spending so much on such a vanity.. then stuff like this happens..lol |
Originally Posted by Kevova
(Post 1598115491)
Just a thought If the TC blew up, how did you make it home? TC is bolted to the flex plate and attached to the input shaft It's a fluid coupler.
That is loud. Converter failure and drives and shifts fine don't normally go together.
Run it with the serpentine belt off? I'd try it since it's easy and quick to do.
I am under the assumption that if your torque converter grenaded you aren't moving anywhere at all.
4L80E swap time!! |
Any difference starting in N or even when shifting at idle?
