Electrical issue
I have 2003 Vette- appears it has no electrical problem- hood light not on and tail lights do not light when brake pedal down. One year old battery appears ok - green on trickle charger
For the hood light, are you sure it's plugged in? Sounds stupid, but that seems to be the case every time.
Agree on the hood light harness..
Local ervice department has forgotten to reconnect it more than once. If the harness is still connected, check the bulb. Minces blown once or twice for the tail lights....do the parking lights work? (and) check the fuse(s). |
My 2003 over this past weekend started giving me trouble. The twilight stopped working and front blinker lights stopped working as well, all of this happened at once?? Can anyone recommend someone near Hot Springs Village, Arkansas to check it out??
Originally Posted by Rachelle Fox
(Post 1599242623)
The more items you can help cross off the list, the better. It also helps those on this forum help you diagnose the problem. |
