Mild to Wild not so Wild
i installed a newly purchased M2W on my 2015 Z51 A8 today. I can't tell any difference in the exhaust sound. I already had the programmable exhaust set at Track for all driving modes. So was mainly expecting the car to maintain a drone after it got to cruising speed. I could not detect any change whether the Wild to mild was on or off. cant figure it out unless I got a bad unit. I tried with both remotes. |
Does nothing but open butterfly's nothing more - cheaper to just pull the fuse
With the M2W on the valves should stay open, sound wise no difference when the valves are open in other modes, advantage is you can open or close at will.
If they are not staying open in the on position then yes you have a problem. |
Having your exhaust set for Track in all modes sets the exhaust completely open. A Mild 2 Wild controller has no affect.
I have mine set to Eco mode. So at start up the valves stay open and it’s much louder. When I hit the switch it’s very noticeable on my 17 Z. |
Originally Posted by v.vet's Z06
(Post 1598137570)
Originally Posted by Yoggi
(Post 1598137622)
I like the way the car sounded on acceleration in tract mode exhaust setting. But at a certain speed it would get quite while cruising. I thought mild to wild would keep the exhaust sound all the time. |
Your car is going in and out of V4 mode. When it does additional valves that are further in the exhaust are closing. The Mild 2 Wild will not defeat them.
I installed a range device and pull the fuse for the rear valves (#42 I think). With the range I get no V4 mode and the fuse pull defeats the valves by the mufflers. With an A8, I think the M2W is a waste |
I installed mine about 2 months ago I can notice a difference in sound w/on/off using the keyfob at idle. under acceleration all sounds about the same to me lol....
(Post 1598137622)
I like the way the car sounded on exceleration in tract mode exhaust setting. But at a certain speed it would get quite while cruising. I thought mild to wild would keep the exhaust sound all the time. |
Mild to Wild just gets you from fuse 42 pulled to back in without lifting the hood. Convenient for us early risers that need to sneak out of the neighbourhood with our suit and ties on at 5AM
Originally Posted by HooosierDaddy
(Post 1598137741)
If you have the mild to wild go into settings and set the exhaust to be in quiet mode all the time on the car itself. Then the M2W will make it quiet and loud. Tho it's not gonna be any louder obviously as its not an exhaust or headers..
Can I ask if I have the A8 with the borla xpipe second cat delete would thing be any benefit to installed it.
Update- I changed the sound management setting from track to stealth. I can definitively tell the difference when turning the remote on/off. I haven't taken it out for a drive. Too rainy here. Also, there was nothing in my instructions saying the remote off button was pushed to deactivate the valves. I thought the on button would mean you were activating the Wild to Wild feature. But it's opposite. I was was hoping that with the system set to track, it would keep the valves open while cruising if I so desired. If it doesn't do that, then I really didn't need the M2W. |
