1992 C4 OE injector?
I replaced all 8 injectors recently. One got clogged on the right side and the back pressure pushed the wires out of the connection. When I pulled them off the fuel rail I noticed this different injector and now I am asking if someone replaced this or is it a OE injector? The picture of the bottom view is not visible but I included it just to show it has a different port.
https://cimg2.ibsrv.net/gimg/www.cor...a60f17d5cf.jpg https://cimg1.ibsrv.net/gimg/www.cor...43ad40efec.jpg All 7 injectors look like this one. https://cimg4.ibsrv.net/gimg/www.cor...be6ff6a60b.jpg The different injector is the one on the left. https://cimg9.ibsrv.net/gimg/www.cor...aeddc76376.jpg https://cimg0.ibsrv.net/gimg/www.cor...0c5f29280f.jpg This different injector has 4 holes which is what caught my eye that this injector is different from the other 7. |
I think they are Multecs? Where did you get the new one? Maybe get Bosch from FIC
Originally Posted by aklim
(Post 1598140301)
I chose these injectors after going to Napa and checking on the cost of AC Delco injectors. The job is easy. The only things to note are prop the fuel lines up to prevent a mess. Go slow and easy putting the new injectors in each port. I did my best to keep any debris from going in one of the injector ports. Put the clips on the injector and then push it onto the fuel rail. You believe these are aftermarket injectors? Well that would explain the odd man out. |
Originally Posted by C4in mesa
(Post 1598140831)
https://cimg6.ibsrv.net/gimg/www.cor...cba77679b3.png
Yes they are Denso and they work great.
