85 tpi 3+4....
Hello folks I haven't done anything major to the l89 because I'll be getting a c5 or sti in November.........but I feel as if I have push the c4 as far as she will go.....keep in mind this car was not running when I got it......now I'm just about done doing basic things to bring it back to life from it's 15 year nap I took.....I want to gain 50 to 60 hp with out doing a complete swap or boar I'm looking to spend around 600 maybe ..........I was wanting to do a lt1 intake...cam... different heads...and long tube headers......
****what would I need to do to fit a lt1 intake on a l89?? ****What heads should I go for....or should I just do rockers and springs??? Short of a nos kit am I missing something else I can do to gain some hp??? |
What do I need to do to mount a lt1 intake on a l89
$600.00...... very small budget....a GOOD set of headers will cost that much or more...... 50 hp difference needs a bigger budget. |
Well over any thin grand......I may as well put a downpdown payment on c5 right
Pretty much....these days... the prices of C5’s are heading south like the C4. Ten or fifteen years ago, Different story. |
A used nitrous kit will fit your budget.
I think you mean L98.
Swapping the intake is going to require welding and machine work. It will allow the RPM range to shift and make more upper HP but trade off peak and average torque. It will make the car faster but won't be cheap. $600 is not enough money to make real gains. I am with the used Nitrous kit. Other suggestion is gear. What gear do you have? The TPI will like a 3.54 gear A LOT. If you put a more realistic budget to it and want gains A TPI loves headers/exhaust. The manifolds on them were crap. Gear if you don't already have the lower gear option. AFPR, the TPIs run rich a Small bump of base timing and run premium fuel Port match the Intake/Runners/Base.... get more air and maybe a few RPM |
Originally Posted by KyleF
(Post 1598181256)
Swapping the intake is going to require welding and machine work. It will allow the RPM range to shift and make more upper HP but trade off peak and average torque. It will make the car faster but won't be cheap. $600 is not enough money to make real gains. I am with the used Nitrous kit. Other suggestion is gear. What gear do you have? The TPI will like a 3.54 gear A LOT. If you put a more realistic budget to it and want gains A TPI loves headers/exhaust. The manifolds on them were crap. Gear if you don't already have the lower gear option. AFPR, the TPIs run rich a Small bump of base timing and run premium fuel Port match the Intake/Runners/Base.... get more air and maybe a few RPM Ok everyone just keeps saying intake swap it and not a way to do it ! |
(Post 1598181256)
https://www.eecis.udel.edu/~davis/z2...ke_conversion/
Currently headed down this route. I had access to a machine shop in college where I milled the casting flat in the back and CNC'd a distributor spacer after measurements. It's been a long process yet to be proven. A mini ram is probably a better path except all of this has been no cost to me so far. |
With your limited budget it's what you're can DIY and a little luck in finding inexpensive used parts. Headers and exhaust ( used LT1 low cost option). LT1 sbc intakes show up for sale but usually over 500. DIY Match porting and larger runners will fit your budget.
