-   C7 Tech/Performance (https://www.corvetteforum.com/forums/c7-tech-performance-169/)
-   -   Is this header tick or someting else (https://www.corvetteforum.com/forums/c7-tech-performance/4200037-is-this-header-tick-or-someting-else.html)
n_brio 10-12-2018 12:11 PM
Is this tick header tick or exhaust leak or is it someting else in the moter that is wrong?
ticking
http://sendvid.com/ktfvx04u
Ticking 2
http://sendvid.com/mqmgnv2t
f1reb1rd 10-12-2018 01:27 PM
I wasn't sure what i was listening to some of the sound seems like the sound the direct injection make which is normal. Maybe someone else has another option
witness140 10-12-2018 06:11 PM
Do you have any recordings from the driver seat with the door closed? Not hearing anything crazy in your videos but hard to compare to mine because I don't drive it from underneath. :)
I did notice that you are leaking muffler bearing grease at an alarming rate.:rock:
n_brio 10-13-2018 03:34 AM
I can clearly hear the ticking inside the car when driving.
fishpick 10-13-2018 08:09 PM
At like 2400 RPMs it’s the loudest?
n_brio 10-14-2018 08:22 AM
Yes it is
Internets_Ninja 10-14-2018 10:06 AM
Hmmm it did not really sound like anything serious. Based on what I heard I would check your idler pulleys to make sure they are in good condition and not leaking grease from the internal piston mechanism. When they go bad they start to make a sloppy ticking sound that can be confused as engine noise. Next I would check for an exhaust leak at the exhaust ports(manifold gasket) and then at the header flange to X pipe. It almost sounds like a mild leak at the header flange. Typically if you have an exhaust leak at the exhaust port the ticking is very sharp but your video(at least how it sounds) seems to be a little more of a sloppy ticking noise.
fishpick 10-14-2018 10:34 AM
There’s a thread I started in the Z06 forum. Took mine to dealer for that sound. It’s the DI pump. Only hear it in my 19 from like 1800 - 2400 and then it’s instantly gone.
Took me a while to notice because I was driving the car w/o top and or windows open.
2 new 2019s sound exactly the same.
Non-issue. Send it.
Muzzi 02-13-2020 11:32 AM
ticking
Ticking 2
I have the exact same sound in my car, did you figure out what it was?
