nspctr1 |
10-12-2018 08:37 PM |
Ignition issues
Still trying to figure out my wiring on my 81. I bought it non running and am reassembling the car. I have removed the computer and am trying to figure out the wiring that resides under the console and around the shifter. I have attached the neutral safety switch but there are a couple more harnesses that are not attached to anything.I assume they are for the ECU but not sure. I have a schematic but having trouble figuring most of it out. anyway, I used a jumper on the neutral SS to just bump the motor and that works so my question is, will the alarm prevent it from starting? is there a way to disconnect it and or remove it? any ideas on what else it may be?
