what years had 8.5 rears?
externally can i tell what i have in my 1976, or do all from a certain year up have 8.5 rears? I want to order gears before taking anything apart, In don't see any tag other than use posi additive tag.
1963-1979 had the same rear ends (Eatons). 1980 and up had Danas I believe.
but, where they 8.2 or 8.5?
They are Corvette specific, other gears won't fit. I've never heard the size listed, but there's lots I don't know!
Originally Posted by bigfish_Oh
(Post 1598153856)
Strange list thisPart Number: RS01884411CXApplication |
(Post 1598155143)
If you are using the stock 3 series carrier you want the thick gears. I would check the gear ratio you have now before
ordering just to be safe. Most automatic cars came with 3.08 ring and pinion gears and I do not believe they offered a 4:11 from the factory in 1976. |
I have a 3.70 or 3.73 which ever was offered for the vette.
thanks for the clarity. |
3:70 was the stock ratio, 3:73 was/is offered by Tom's. There are more teeth on the gears that is the difference. You can still buy new 3:70 gears but they are all imported. Tom's are still USA made and there is no difference in driving feel or speedo gearing.
As mentioned the vette gears are specific to corvette. If you are new to corvettes and have an original 76 diff you have questions on then you should know some things 1- the stock axles are soft faced and should be replaced 2- clutches are what I refer to as SnowFlake type and are weak. Solid Steels should be installed, forget about fiber coated clutches. 3- Some 76's got the flange head ring gear bolts, which backed out many times Check your LH housing wall for gouging to know if this happened. Use ARP RG bolts over the weaker kit RG bolts a rebuilder uses to save time and increase profit. The $35 or so for the ARP's is worth it. 4 - GM gears have the date and tooth count( ratio) stamped on the side of the ring gear so you know what is in there. |
