2008 ZO6 JSB 1,000 RWHP 11,000 miles
https://cimg0.ibsrv.net/gimg/www.cor...22c0a6012b.png
I bought this car new in 2008. It took me 10 years to get the car where it is today. Car has 11,000 miles, built motor and blower setup have 3,000 miles. The car has clear bra and is in like new condition. I am asking $50,000. Details will be listed below. |
Very cool car! And you bought it brand new!!
GLWS...:thumbs: |
MOTOR= ERL superdeck 6-bolt head compatible, Callies dragon slayer crank, callies rods, wiseco pistons, ARP big head studs, ARP bolts, darton sleeves, WCCH ls7 heads all fixed and worked up, Comp Cam special grind specd by Billy Godbold, comp valve springs, ls7 intake with cool under mat, ls7 throttle body, Steam vent kit, stock water pump, stock ls7 dry sump
BLOWER= A&A new style black brackets, Vortech YSI-B black blower, 10 rib conversion, A&A accessory flip drive, 8in. ATI crank pulley, 2.75 blower pulley 2 Tial Q BOV, A&A intercooler EXHAUST= Kooks 2in primary to 3 in. collector, Kooks 3in. off road x pipe, B&B fusion mufflers DRIVELINE= Mantic 3 disc clutch, Quicktime safety bellhousing, DSS 1 piece carbon fiber prop shaft, Stock Tr6060, ECS trans brace, Stock ZO6 diff, DSS axles, Ecs axle loops, MGW shifter, Hawks performance adjustable master cylinder, Carlyle 15in. conversion with LG spindles FUEL= A&A inline big Holley pump, 10an +8an lines, holley boost referenced regulator, ID 1300 injectors, AEM methanol system, aeromotive fuel rails COOLING= Dewitts full size radiator, with modified radiator support allowing 4in. intake pipe to blower. TUNE= car has been dyno and street tuned. Very safe tune and not meth dependant (car wont lean out if out of meth) tune is on 93 octane. Car drives great. OTHER= mighty mouse wild boost catch can with 10an lines to each valve cover, aeroforce interceptor gauge, autometer wideband gauge, autometer electric fuel pressure gauge, coil relocation kit, billet valve covers, sure i am forgetting things at this time.... |
Originally Posted by bartsky
(Post 1598178038)
GLWS...:thumbs: |
Vouch for car and seller!!
Originally Posted by TBSS913
(Post 1598180174)
Originally Posted by Blue by U
(Post 1598180188)
thanks biv!
Vouch for car and seller as well.
(Post 1598180317)
It's Cody haha
Originally Posted by lwshack
(Post 1598180910)
Where are you located |
Originally Posted by Z06streetracer
(Post 1598186384)
What kind of horsepower does that make to rear wheel the way it sets
(Post 1598186432)
Knoxville, TN
Originally Posted by Bob Moran
(Post 1598187689)
what kind of horsepower does that make to the rear wheels the way it is on pump gas
(Post 1598178110)
BLOWER= A&A new style black brackets, YSI-B black blower, 10 rib conversion, A&A accessory flip drive, ATI crank pulley, 2.75 blower pulley 2 Tial Q BOV, A&A intercooler EXHAUST= Kooks 2in primary to 3 in. collector, Kooks 3in. off road x pipe, B&B fusion mufflers DRIVELINE= Mantic 3 disc clutch, Quicktime safety bellhousing, DSS 1 piece carbon fiber prop shaft, Stock Tr6060, ECS trans brace, Stock ZO6 diff, DSS axles, Ecs axle loops, MGW shifter, Hawks performance adjustable master cylinder, Carlyle 15in. conversion with LG spindles FUEL= A&A inline big Holley pump, 10an +8an lines, holley boost referenced regulator, ID 1300 injectors, AEM methanol system, aeromotive fuel rails COOLING= Dewitts full size radiator, with modified radiator support allowing 4in. intake pipe to blower. TUNE= car has been dyno and street tuned. Very safe tune and not meth dependant (car wont lean out if out of meth) tune is on 93 octane. Car drives great. OTHER= mighty mouse wild boost catch can with 10an lines to each valve cover, aeroforce interceptor gauge, autometer wideband gauge, autometer electric fuel pressure gauge, sure i am forgetting things at this time.... What did it do on meth? How much psi are you running? |
Originally Posted by x88
(Post 1598189517)
1000 hp without meth, 93 only?
https://cimg8.ibsrv.net/gimg/www.cor...2f613e4c4e.jpg
Here is the actual mileage on the car today. I do still drive it when nice out, so it will go up. Car does not have a check engine light. Car is not running. Just wanted to get a mileage picture. |
