will LSA blower work on LS7
My friend has a blower ff a LSA motor. Can that be installed on a LS7? If so what would it take? And is it worth doing? Will my computer work, and I have a fuel system set up for 1200HP, hope that will be ok.
Thanks looking for input |
You can make anything work if you want to. It will require some parts to be made like adapters to make the head intake ports line up with the blower. Its a lot of work to only make 700 hp. You can buy other kits that will make the power and be less work.
Your best bet would be to swap LS3 heads onto the car first. Then the blower will bolt right up.
