https://www.corvetteforum.com/forums/
C6 Parts for Sale/Wanted
https://www.corvetteforum.com/forums/c6-parts-for-sale-wanted-115/
FS:
Vengeance Racing Used and New Parts via EBAY
https://www.corvetteforum.com/forums/c6-parts-for-sale-wanted/4206669-vengeance-racing-used-and-new-parts-via-ebay.html
Vengeance Racing
10-29-2018 09:04 AM
Please click the links below for more information... You can make offers through the EBay listings
C7 Specific Items
Procharger GM Gen5 Intake Manifold for LT1 or LT4
GM Factory LT1 Pistons & Wrist Pins (Gen 5)
C7 Corvette Stingray Alternator - 22868687
LT1 (Gen 5) Oil Pump - 12686436
LT1 (Gen 5) Rear Engine Cover - 12623310
C7 Corvette LT1 Oil Cooler - 12658068
C7 Z06 18% Overdrive Pulley
C6 Specific Items
C6 Corvette Headlights - White (2005 - 2013)
Vengeance Racing Tall Valve Covers - LSx Gen 3 or Gen 4
McLeod Mag Force Clutch For LS Applications - Twin Disc
FTI Torque Converter for C6 Corvettes - 6L80 Trans
Wiseco Forged Pistons for LS Engines -27cc 4.135" Bore
GM LS Rear Engine Cover - 12572014 (Gen 4 Engines)
C6 Z06 Complete Torque Tube - 19132932
Vengeance Racing Camshaft for Supercharged LS7 Engines 239/254 .662/.651 115+4
C6 Hood - Black
Hydratech Brake Boost System For C5 Or C6 Corvettes (#3009-BASE)
C6 Custom Air-to-Air Intercooler (1000HP+)- For Twins
C6 Z06 Door Panels - 2007 - Ebony (with Bose)
C6 Z06 Rear Splitter - Carbon - Gloss Black (2007)
C6 Z06 Non-Removable Roof Panel (Hard Top)
ARE LS7 Style Dry Sump Pan With 2-Stage Scavenge Pump
C6 Passenger Side Air Bag
C6 XM Radio Antenna
Rear Cover for GM LS Engines - 12598301
C5 Specific Items
C5 Z06 Front Sway Bar FE4 / Z06 10419094
C5 Z06 Rear Sway Bar FE4 10424743
Mechman C5 Corvette, 170 Amp Alternator
C5 or C4 Corvette Headlight Module - 16523917
C5 Wiper Control Stalk Switch - 260047377
C5 A&A Corvette Secondary Belt Drive (single Bracket And Belt Only)
General Purpose Items
FTI Triple Disc Torque Converter for 4L80E and LS
Toyo Proxes A40 Tires 215/45R18
Gates 10-rib Green Belt - K100658HD
Gates 10-Rib Green Belt - K100655HD
Manley Chrome Moly Pushrods 7.750" .080 Wall 3/8 Dia
Carillo Connecting Rods - Custom 6.460-Inch
Gates K080842 8-rib Belt
Gen 3 LS Valve Covers
MAST Motorsports Rocker Stands LS7 Big Bore Heads
Casper's Electronics LS Coil Pack Extensions (Pair) - 109082
Fabricated Fuel Cell / Ice Tank / Trans Cooler Box - NCC (No Corners Cut)
Morel LS Tie Bar Lifters - 5850 - Short Travel
Pro Torque Converter TH400
DCM Axial Electric Puller Fan - 860026
Holley 860015 102mm Sniper Throttle Body Spacer
Mass Airflow Sensor For LS Engines - 5-Wire
Cometic LS7 Head Gasket - C5889-070
Wiseco Wrist Pins For LS Engines
Mantic 9000 Series Flywheel - F9001H
Gates K080855 Belt - 8PK2173
CM Pushrods 7.225" 5/16" .080
CM Pushrods 8.050" 3/8" .080
Cometic MLS Head Gasket (Left Side)
Durabond CH-23 Cam Bearings
Vengeance Racing
10-04-2019 11:15 AM
Weekend bump
05:55 PM
