What brand headers are most "quiet"
strange question maybe.... but i f i want to remove exhaust restriction and put on headers, i do want the header set that give least "ping" sound inside and outside from engine compartment...
Maybe not a good way to explain it, but i guess thicker wall, and coating inside out will help reduce temp and noise ? Looking to get a stealth power upgrade... :-) Rune |
turbos :D
I have modded many cars and nothing gives a bigger hit to good NVH than adding headers. But it gives some nice hp gains, so most put up with the noise, heat and vibration.
Get a Prius!
Engine headers
The set of American Racing headers ceramic-coated inside and out my last 3 ZO6 had them on my opinions are the best
Kooks catted headers. :)
-Josh |
The ones left hooked to the stock cat back. That said I prefer ARH coated 2 inch!
ARH mid length headers. In tour mode not much louder than stock
Originally Posted by Corvette4ever
(Post 1598253500)
yeah it seems odd to worry about noise in our cars, but there is two sides... 1. i don't like the crackling noise in cabin when driving on street 2. and most important.... Europa tracks are getting real Nazi on noise level.... just see how Lou struggled. I did a track day 2-3 weeks ago, and was black flagged after one lap..... rest of the day i had to lift out of turn 5 and leave it like that for 300+ feet..... kind of take the fun out of it... Still smashed every one of the P car around, 991.1 GT3 and GT3 RS........ So we have a quick car.... just need to tone noise down :-) Thanks for all reply... Anyone want o guess how much HP i loose by staying stock exhaust ? Lets say i upgrade to 2300, heads and cam and shoot for 750 Hp with headers.... and then dont do headers ? anyone know ? Rune |
Originally Posted by Z06Norway
(Post 1598249183)
Originally Posted by pkincy
(Post 1598249990)
If you’re looking for stealth, definitely keep cats. My non catted with valve open is insanely loud, apparently on the stock Z mufflers with valves open is just like straight pipe unlike the previous generation (c6z) bi-mode mufflers. |
NONE, there all louder. I have kooks with a 2300 heartbeat , afe x tank pulley and it’s much louder than stock. When I’m in touring or 5 & 6fh gear the exhaust is closed and it’s as quiet as stock. |
Originally Posted by andreas g.
(Post 1598269004)
NONE, there all louder. I have kooks with a 2300 heartbeat , afe x tank pulley and it’s much louder than stock. When I’m in touring or 5 & 6fh gear the exhaust is closed and it’s as quiet as stock. And travelling to tracks 10-15 hours from home only to sit in PIT is not my cup of tea :-) So it seems i am forced to stay stock or find a solution that breathes better but reduce Db music out of rear pipes :-) I know of a guy in Switcherland that has a setup.... it includes a set of extra CAT pipes at the outlet... looks funny, but is quiet..... So i keep looking |
Have you considered Hooker shorty headers? 19 lbs lighter than the stock manifolds, and a little more power.
http://www.superchevy.com/how-to/exh...your-c7-vette/ I doubt they would be much louder than stock. |
Some may disagree, but I would actually call some of the really good aftermarket header and exhaust companies and get their input. You may be able to put some additional mufflers of some sort in-line somewhere in the existing system to help. It's worth a shot, they would know more about sound mitigation than we would. You never know, it may lead to a new product for all of us to use at tracks like that.
I would think noise is equal on all headers for the most part, so like others have said that decision should be made based on power, fitment, quality of construction, and metal quality. |
Trust meon this. Do my main cat delete and keep oem acle back proven combo.
Originally Posted by NORCAL-SS
(Post 1598632855)
Z06Norway, I think you kind of have your answer from 1) what you've experienced even with stock exhaust in your last post above, and 2) Lou's go-round with the Ring officials. I'm sure Lou started w. a Z, added lots of hp, took off OEM headers, exhaust, and then had to keep adding back on angled exhaust, mufflers, etc. and was close to/still wasn't sufficient for the Ring officials.
Whatever you try to do, a la the Switzerland experiment fellow, keep your old stock stuff in case you have to put it back on. It may be that if this fellow makes enough of a "quiet" muffler or cat, you may be able to not only quiet down your stock headers but maybe even add aftermarket headers???? Keep us posted. |
Originally Posted by fatsport
(Post 1598633487)
How much lighter? Us track guys care about weight more than power. It’s baffling to me that all the vendors on here don’t tell us weights with there products. The C7 Z06 is an amazing car, but it’s 250lbs heavier than the previous generation. |
