C8 Price Poll
Guess the starting price of a C8...
If the MR is an exclusive model, $130K. If it's the standard and all C8's are MR, $85K. If i'm right on either, that just sucks.
I am really surprised by the wide range of prices being thrown around as we speculate on the C8 pricing. I figure a simple poll will enable us to get a better consensus. |
Originally Posted by falcon5619
(Post 1598257756)
If GM labels this mid engine car as a new generation Corvette there is no reason to expect it to be more than $65k starting. If GM brings it out as a top tier above ZR1 offering with a C7 refresh then it could be more, but I don't see it being priced too much higher than the ZR1 in that case.
Originally Posted by Supermassive
(Post 1598258528)
70-75 imho
Is this poll MSRP? If so, $57,749.99 for a base. 5% increase from previous model.
2/3 correct
2/3rds of the voters are correct $60K-$75K
(Post 1598257756)
I'm heartened to see that approximately 75% of forum members are rational and close on pricing. It's a small minority clinging to the bizarre notion that GM will only offer a 6-figure ME model.
Hey man... How come that over 100 000$ guy gets to vote 9 times.... What a heck! |
Originally Posted by sweedjeff
(Post 1598260542)
Originally Posted by pietro c7
(Post 1598260903)
Are we sure the camo'ed ME car at the Ring is the replacement for the C7 and not a new model to be built in parallel with a FE model C8? If so, the 65-75 range sounds about right, although I'm not sure how they will do that without cutting corners on fit/finish/material quality.
If the camo'ed ME at the Ring is not a replacement for the C7 and instead is a new model to be built in BG along with a FE car, then all bets are off and it could easily start much higher. The $130k mark someone else mentioned doesn't sound too crazy. But we just haven't seen enough of the real car (brakes, tires, wheels, interior, unmasked exterior) to have those answers. |
Based on the trend in the poll so far if a base C8 costs more than $70k then it will have to add a lot of value over the base C7 beside just a mid engine configuration.
IMO, in order to justify a starting price of $70k or higher then a base model should at least include: - 500-525 NA horsepower - 500lb ft of torque - Weigh 3100-3200lbs - ZF DCT that doesn't shudder, hopefully a manual trans as well - Mag ride tech standard - E-Diff tech equivalent standard - 6 piston brake calipers and larger GS/Z06 size rotors - Performance Exhaust with programmable modes - Hi-res infotainment screen, maybe 10 inch display - Safety Tech standard (RCTA, Blind Spot Monitoring, Front and rear cameras, etc.) not a deal breaker for me but it should have it at that price. |
(Post 1598260903)
Originally Posted by F4 Phantom
(Post 1598263299)
WTF! Lay off the crack!:ack:
meaning there can’t possibly be more the 1 individual that would have checked off the 100 000$ plus option, I guess it didn’t pan out,sorry |
(Post 1598262209)
IMO, in order to justify a starting price of $70k or higher then a base model should at least include: - 500-525 NA horsepower - 500lb ft of torque - Weigh 3100-3200lbs - ZF DCT that doesn't shudder, hopefully a manual trans as well - Mag ride tech standard - E-Diff tech equivalent standard - 6 piston brake calipers and larger GS/Z06 size rotors - Performance Exhaust with programmable modes - Hi-res infotainment screen, maybe 10 inch display - Safety Tech standard (RCTA, Blind Spot Monitoring, Front and rear cameras, etc.) not a deal breaker for me but it should have it at that price. My bet is an MSRP with freight of $69,995, but it will be the equivalent of today's plain jane Stingray Z51 1LT A8 with MSRC. |
Originally Posted by LIStingray
(Post 1598263586)
That is some good crack you are smoking - a GS 2LT A8 (what is required to get F&R cameras and close to a DCT) is over $72K MSRP. Yet, for $70k in addition to that, you want to reduce the weight by at least 300 lbs, and at least 40 hp and add RCTA and BLS.
My bet is an MSRP with freight of $69,995, but it will be the equivalent of today's plain jane Stingray Z51 1LT A8 with MSRC. So, let's say none of what I want is offered. Why would I trade my C7 GS Vert with M7 for a C8 then? There would not be enough value for existing owners to upgrade, other than just upgrading for the sake of upgrading? |
(Post 1598260542)
