answer to cooling woes? maybe.
https://www.onallcylinders.com/2018/10/30/sema-2018-proform-slim-fit-radiator-systems-might-change-life/?utm_source=feedburner&utm_medium=email& utm_campaign=Feed%3A+OnAllCylinders+%28O nAllCylinders%29 From the new SEMA show. might have to get one and says great for LS swaps too.
Don't like anything attached to the core of an aluminum cross flow radiator
E-fans vibrate. If the side slots are designed to allow more airflow through the radiator @ highway speed to aid cooling the design is flawed. At idle the fan will circulate some engine bay heat instead of pulling all air through the core. The slots need flappers they will blow open @ highway speed & otherwise be sucked closed. IMHO: A poorly designed niche market item. |
https://www.corvetteforum.com/forums...cons/icon1.gif" answer to cooling woes?"
What cooling woes? Owned LT1 C4s for 19 years, and never experienced a cooling problem. |
I'd use it only if space were at an absolute minimum. The concept is interesting but you give up a large percentage of the cooling area of the radiator, plus I'm not sold on having the aluminum core support the fan and fan motor. Whatever happened to fan belts and mechanical fans?
