Purpose of 2.5" sleeve to downpipes?
I have Ramhorns with 2.5" outlets, and 64-65 2.5" downpipes....
Do I have to use the 2.5" sleeve shown in the images below? (Between the donut and the downpipe?) I'm going to go check to see how it bolts up without it, but I thought I'd ask also..... https://www.corvettecentral.com/c3-6...c2%26count%3d9 https://cimg6.ibsrv.net/gimg/www.cor...3b7460b80d.jpg |
The purpose of the insert "sleeve" was to prevent you from burning the packing out... Always use them! It will bolt up fine without it, but it acts as a barrier between the hot exhaust and the packing.
Ernie |
Look here:
https://www.castheads.com/manifolds-...pes-pipe-kits/ One of these kits could be adapted to eliminate the packing and sleeve Not cheap, but you would have a true 2 1/2" exhaust. |
Originally Posted by Willcox Corvette
(Post 1598267224)
Ernie What's this packing of which you so boldly speak? |
Originally Posted by Priya
(Post 1598272130)
Willcox |
Because it looks somewhat like a donut?
Thanks for the info. Guess I'll use the sleeves..... good thing I've learned to ask around here instead of just ASSuming things. :D
I like the "Donut" gasket term.... communicates the information and provides a visual description in your mind. So far it looks like those 2.5" 64-65 downpipes are going to fit quite well into my 68. |
Originally Posted by carriljc
(Post 1598276871)
I like the "Donut" gasket term.... communicates the information and provides a visual description in your mind. |
Originally Posted by resdoggie
(Post 1598275784)
