Someone forgot to reconnect a hose? LT1 coolant system
Trying to work on the car I came across this. See that Tee fitting there? Now I know why there was a puddle where I parked and why the brace between framerail and A-pillar was rusty. But I have no clue what to do about this connector. The hose that is connected seems to go to the radiator. Now the other end... I just can't find anywhere to connect it to.
https://cimg7.ibsrv.net/gimg/www.cor...cd1ea7fda7.jpg would love to see pictures of what the coolant system should look like for an LT1. Really need to figure this out... |
That actually looks like the tee in a later LT1 for secondary AIR. Cars with the TEE just had a filter over that 'nipple' I'm quite sure.
https://cimg1.ibsrv.net/gimg/www.cor...5c894db725.jpg |
Interesting... Then it not being connected wouldn't be a big deal, so that's a good thing. But that does make me wonder what caused the rusting in this area and where those puddles came from...
Originally Posted by PerKr
(Post 1598271104)
Do you have the FSM for your car? |
Originally Posted by WVZR-1
(Post 1598271210)
Is the balance of the Secondary AIR there? I only offered up what I thought it to be. You need to confirm. What year is your car? A 'big deal' that depends I guess - but if it is Secondary AIR it's got no relationship to 'coolant' as you mentioned thinking.
Do you have the FSM for your car? I have the Haynes manual but it seems to consistently lack the information I need when I get stuck 🙂 |
It was the AIR. Which means I haven't driven her 200 miles without coolant. Which is sort of a relief. Still need to deal with it though, if possible.
(Post 1598283556)
(Post 1598283678)
I'm thinking someone removed the system. Partially. It should connect to the exhaust manifolds on either side, right? At the middle tubes? Well, someone plugged what looks to have been threaded holes there. So I'm going to leave that for now and focus on the other issues this car has.
(Post 1598286841)
I had seen in your original snapshot what appeared to be likely a 'plug' in the manifold but I thought it maybe better to just point you towards how it should have been if original.
