traction control 96 vette
96 collectors edition Lt1/auto: Had a bad plug wire, looked scary so I went with very good wires, all is well except the traction control. It works fine its just that the button to
turn it off does not work. any ideas???? thanks again Preacher Putz |
I would make sure it's plugged in.
How do you know it doesnt work? Maybe the bulb is just burned out?
Traction control is now working ok, was a poor connection. Used a little connector cleaner (DIOXIN). Thanks for the help, The vette has been down for repairs for a few months, and just started it up, everything worked except the traction control, and I went into brain fade.
thanks again Pr. Putz |
Pretty good if that was your only issue after being down that long.
