Timing advance
Hi everybody!
It's me again from Italy! A lot of rain these days so I had time for get lost in some technical thoughts… Timing advance… I have a 1969 L36 engine and the factory indications give 4° advance at 800 rpm (manual transmission). Actually I hear that the most part of the people prefer have more advance in these engines, like 8 or 10°. I really can't understand why…: in the past the petrol had more octane so more anti-knock effect than actually; consequently the timinig advance should be less today… What do you think? |
The stock timing curve had to suit (ie: survive the warranty period) all the octane/weather/climate/altitude conditions that the thousands of cars might see, so the timing was purposely less-advanced/retarded compared to the optimum/proper timing curves for each engine/environment. Just put the timing curve in that makes your engine happy/responsive for your octane and climate/altitude situation.
[QUOTE. Just put the timing curve in that makes your engine happy/responsive for your octane and climate/altitude situation.[/QUOTE] :iagree: |
Use manifold vacuum for vac advance and set initial at ~12* and go from there.
L36. Big block. They like about 36 max centrifugal timing at 3000. Don't have a dial back light? Put the timing mark on balancer at 10 degrees btdc mark on timing tab. Paint a line on balancer at 0 mark on tab. Put that Mark at 10 degrees btdc. Paint another Mark at 0. Now you have 0. 10. 20 marks on balancer. When you see 20 mark at 16 on tab with timing light, you are at 36 btdc. Without vacuum at 3000. Drop to idle. You should see 0 mark around 8 to 16. Hook up vacuum. You should see 20 mark around 10 or so. rev with vacuum hooked up. You should see 20 mark on balancer run off past the 16 mark on tab.
Your timing at idle is the least important setting. You need enough advanced timing for power-economy. You need little enough advance under load that you don't burn pistons.
Read this and then email Lars for his timing instructions.
https://www.corvetteforum.com/forums...long-post.html |
Thanks to everybody
(Post 1598282285)
Actually Derek is correct. Of the four IGN Timing events, initial IS the least important.
Total Timing w/o Vac Total Timing w/ Vac Mechanical Advance & degrees of limit. Initial Timing There is an old saying that still holds true today. Set your total at 36 and let the initial fall where it may. And your statement about W.O.T makes no sense. Your Total Timing is configured for anything above 2200-3000 RPMs. Not just W.O.T. And "that" mid range RPM is where 99% of Corvettes spend 99% of their time. |
Originally Posted by HeadsU.P.
(Post 1598297005)
Actually Derek is correct. Of the four IGN Timing events, initial IS the least important. He didn't say "initial", he said "idle timing". Let's try to be accurate here.
Total Timing w/o Vac Total Timing w/ Vac Mechanical Advance & degrees of limit. Initial Timing There is an old saying that still holds true today. Set your total at 36 and let the initial fall where it may. There's also another old saying: "Road hugging weight". Just because it's an old saying doesn't mean that nonsense should still continue to be propagated. And your statement about W.O.T makes no sense. It does to most anybody who drives a car. Your Total Timing is configured for anything above 2200-3000 RPMs. Nonsense. Not just W.O.T. Who said "just WOT"? And "that" mid range RPM is where 99% of Corvettes spend 99% of their time. And your point is? If you want to take this topic deep, I'm all ears. |
Post #7 covers it perfectly.
The idle timing will end up being whatever it is: 36 deg (or so) minus the total mechanical advance, all-in at 3000 RPM. The one thing to check is that the advance springs hold the distributor to zero mechanical advance at your idle speed. Unless you are an expert witness in an Alabama courtroom, you will never need to know the idle advance. |
the thing with the wide open throttle Advance, is it has to stop at a certain point. If you're running 42 or 46 degrees of Advance at wide open throttle you're going to be burning up your Pistons. That's why that went is the most crucial timing event. It's not that it has to be high enough, which it does it has to not be too high or really bad things are going to happen.
Me personally....I would set total timing to 36 degrees and let the initial fall where it falls........anywhere between 12-16 degrees on a stock distributor.
Stock GM was like 30 degrees total........you will not believe the difference 6 degrees makes on total. Jebby |
Semantics aside, what is technically wrong with setting the timing the way half a dozen posters have now suggested?
Paraphrasing (the full answer is still in Post #7, especially the part about emailing Lars) Make sure everything else is in proper working order (distributor advance moves freely, set gear lash, etc). Ensure all-in mechanical advance at 3000 rpm (lighter springs in the distributor) Set full mechanical advance to 36 degrees btdc (vacuum advance disconnected) Let the initial, or idle, or whatever you want to call it advance fall where it may (go ahead and check) Use manifold vacuum on an advance can limited to about 12 (+/-) degrees of advance Check for pinging, adjust idle speed, make sure that you don't have mechanical advance at idle (or else you need stiffer springs) Isn't that what everyone is saying? Does it matter the degree of importance of the initial advance, if it's not a variable you can adjust with this method? |
Originally Posted by Bikespace
(Post 1598303765)
3k) Does it matter the degree of importance of the initial advance
