{*GROUP*BUY*} McLeod RXT Street Twin Clutch Kits 6405507M
I am trying to put together a Group Buy for these clutches, probably 5-10 person. You'll have to PM me or email support@wildvettes.com for pricing as it is going to be too low to advertise. LS1/LS2/LS3/LS6/LS7 :cheers:
https://cimg0.ibsrv.net/gimg/www.cor...b620b16531.png McLeod RXT Street Twin clutch kits are ideal for the extreme horsepower enthusiast who wants performance and economy. Capable of handling up to 1,000 hp, the RXT Street Twin clutches are for those who've kicked it up another notch—but still require streetability. The ceramic facing on the clutch discs provides slightly aggressive engagement with a soft pedal effort, making these clutches suitable for most street performance enthusiasts. Match your vehicle specs to the correct model from McLeod. Additional features include: * Alignment tool * Lighter-than-stock pedal feel * Will bolt to factory flywheel * CNC-machined and anodized flywheel adapter ring * Smooth engagement with excellent release qualities * Ceramic facings on disc increase holding power over similar organic linings * Low rotating mass for quick revs * Blanchard ground floater with multiple straps to reduce noise for streetability PartNumber 6405507M Description RXT TWN ASSY LS 6BLT CRK 1-1/8 X 26 SPLINE BRZ FACING 168 Alignment Tool Included Yes Clutch Patterns RST/RXT Steel Adapter Plate Pattern Clutch Usage Street Disc Diameter 9-11/16" Disc Material Ceramic Disc Style Sprung Hub Engine 6 BOLT CRANK Flywheel Included Yes Flywheel Material Steel Hardware Included Yes Horsepower Rating 1000 Hub Style Solid Make Chevrolet Number of Discs Double Pilot Bushing Included No Pilot Bushing Material N/A Pressure Plate Style Diaphragm Ring Gear 168 tooth Spline 1 1/8" x 26 Throwout Bearing Included No Throwout Bearing Style |
3 in so far. Let's try to get this done so we can ship Monday. :cheers:
LAST CALL, taking money from people now, looks like this will be a go!
