H/C/I/E C6 Z06 smoking under WOT
Hey all, im having some trouble narrowing down whats causing my Z to billow out some smoke under WOT pulls. Im also getting some very LIGHT smoke at idle (as in the sunlight has to be in the right spot for me to see it). The car consumes about a quart to a quart and a half of oil between oil changes. Im running mobil 1 5w 20 currently but i have ran the VR racing 20w 50 before and still had the same issue, also currently have a catch can on the car. Ive replaced the valve guide seals and performed a leak down test which came back good yet the problem still persist. The car runs great power wise, traps 10.45 at 133/135 range which seems to be on par with car z06s with similar mods, i just want the car to stop looking like the union pacific going down the track. Heres a list of mods if it helps anyone point me in the right direction.....thanks to anyone that can help
AHP heads milled .040 MSD intake LS7R cam TSP longtubes and catless mid Flex fuel sensor (e85 and 93 mix) Catch can (dont know the brand) NW102 TB |
Dont want to go sideways on your thread but...wtf are you running 5w20 for?!
Not all brand catch cans work the same on our (dry sump) cars. Have you pulled the TB and looked inside your intake manifold to see if you have oil in there?
Have you gotten under the car to look for leaks? Could just be an oil pan gasket leaking onto the exhaust and blowing smoke behind you. |
Originally Posted by MTPZ06
(Post 1598330652)
yea I've had the manifold apart recently and didn't see any excessive oil in it...maybe a light film but not small puddling or anything of that nature. Back of the throttle body didn't really have any oil on it either |
Originally Posted by Apocolipse
(Post 1598330640)
Smoke under power is almost always ring seal
Originally Posted by ls404fd
(Post 1598331085)
Mine smokes pretty bad at the upper rpms, intake was covered in oil. Have a MMS catch can on now and it still smokes(not as bad albeit). At 62k miles I’m sure it’s the rings. |
Originally Posted by NemeZ
(Post 1598331365)
(Post 1598330640)
Originally Posted by Drew03tx
(Post 1598331126)
that's what I've been told. But the leak down test came back good and the car has 55k on the clock. Could it still be a ring problem that a leak down wouldn't catch?
(Post 1598331504)
thats fairly low miles as well. have you done a leak down on yours yet?
(Post 1598330640)
(Post 1598330985)
well I believe the cap says 5w30...and at the time when I went to the parts store they only had 5w20 Mobil 1, I personally dont think it makes a big difference with the amount I drive it.
This is what blows my mind. GM says 5w-30 for the Gen V LT1 but 0w-20 for the same motor in the truck, (L86.) Now, GM is telling you not to put 5w30 in the LT1 but instead their new lower SAPS 0w-40 ESP, but the 0w20 is still good for the same motor in the trucks. They're sounding like the Broward County Board of Elections here, I just don't think I trust them. Emissions will always be secondary to the longevity of my motor when it comes to motor oil.
Interesting viscosity levels between 0w40 and 5w30, not a huge difference. But look at the 0w20, that's a huge difference compared to 5w30. Sure, the L86 is tuned for a truck, has a slightly different intake and exhaust manifold, but its otherwise an identical long block with the same internal tolerances. https://cimg6.ibsrv.net/gimg/www.cor...f54b683ffb.jpg https://cimg0.ibsrv.net/gimg/www.cor...9218ccfe58.jpg |
^^I’m assuming they have totally different oil clearances.^^ |
(Post 1598333444)
Lower weight oil = emissions regulations to reduce MPG.
Originally Posted by Must_Have_Z
(Post 1598332996)
A difference of "10" in the upper temp weight range is fairly significant. And the "amount you drive it" has nothing to do with the type of oil you should use. Ugh.
