2007 Z06 roller lvl 7 rpm 6060
Sold
:lurk:
bump!!
Bump!
Motor went?
Kinda... it's a fully built RHS block mast headed forged bottom end runs great but the block is cracked. So it's being sold as a roller.
Originally Posted by jaytee8067
(Post 1598417938)
Cracked in between freeze plugs and into one of the head bolt hole, RHS blocks are notorious for it. They are the most expensive garbage aftermarket block you can buy.... and again that motor will not be in the car. No motor, headers or clutch
Price drop 23,000 and including 2" stainless works headers
Price drop 22,000
where are you located?
Says in the first post.....las vegas
Price drop 20k
Bump!
Bump
How about harness, ecu, and accessories such as ac, etc? Are they present or gone?
ECU and harness are there, ac is there and still connected as well as power steering pump.
How did you get the 6060 in the car?...I saw the input shaft on the driveshaft...can you tell us a little about that? Is the torque tube original?
