My C6Z build thread
Hi all, i sold my H/C/I C5Z and picked this up from Oklahoma. The car looks like it came from Florida, then to Texas where it was at 21st Century Muscle car. It's got WCCH stage 2 heads, Callaway Honker, Cup wheels with PFADT longtubes and Corsa catback. It also used to have nitrous on it. The for sale ad said it had a cam, but I'm not convinced of that. If you recognize the car I'd love to hear from you.
When i got it home, the slave cylinder failed and i started tearing into it. It's really become a nightmare since then. I ordered a new Monster clutch (and supporting parts), pulled out the PFADT longtubes and catted X (for sale section), ordered new 2in ARH longtubes with no cats on the X and ordered a factory replacement fuel pump with the Racetronix harness and plug n play intermediate harness for a BAP if the need arises in the future. I'm considering a Trans brace when everything is out, assuming i find nothing else wrong/ broken. When it's back together, i plan to have the tune updated. I spoke to the tuner at 21st and i think its got a nitrous tune on it still. The car feels down on power and off idle throttle response was a little soft. I performed a compression test and everything checked well (big relief). Other plans this winter include a tune up with new plugs and wires, fixing some odds and ends, completely new fluids and maybe some drag radials and a shifter. Anyway, got the car on the kwiklift and started tearing it apart. I found a trash bag jammed under the sideskirt, a wrench up on the bleeder valve the rear tires were mounted backwards and now my passenger window won't roll up past halfway. Ask me about the first day i owned the car. .. Here are some pics i took tonight, this is a fairly in depth job pulling this apart. Enjoy and ill update as i go. Thx, Mike https://cimg9.ibsrv.net/gimg/www.cor...64efb98638.jpg https://cimg2.ibsrv.net/gimg/www.cor...fd7a94fdcc.jpg https://cimg1.ibsrv.net/gimg/www.cor...a915d09980.jpg https://cimg4.ibsrv.net/gimg/www.cor...cc4f23503b.jpg https://cimg3.ibsrv.net/gimg/www.cor...e8f7433fa8.jpg https://cimg5.ibsrv.net/gimg/www.cor...2aeda167a1.jpg https://cimg7.ibsrv.net/gimg/www.cor...b5736e6075.jpg https://cimg0.ibsrv.net/gimg/www.cor...ef3739ba09.jpg |
:lurk:
Update. Exhaust, fuel pump with harness and clutch have all arrived. Space is tight in the garage.
I got the drivetrain out. I'm not familiar with working on these cars (came from mustangs) and so every nut and movement took longer than normal. I should get the clutch out this week and get a chance to inspect that and the slave. I will also likely put in new torque tube couplers and bushings. Where is the best place to get those parts? i picked up a trans jack from harbor freight and used some cedar to get the cradle down. Also, see the pic of the cabin air filter i replaced... nasty. Also, picked up a $20 wood dolly from lowes that will allow me to move the drivetrain around and store it under the car. Enjoy the pics! https://cimg7.ibsrv.net/gimg/www.cor...bfb3ef6862.jpg https://cimg2.ibsrv.net/gimg/www.cor...9202b3043e.jpg https://cimg7.ibsrv.net/gimg/www.cor...5da13cb896.jpg https://cimg9.ibsrv.net/gimg/www.cor...9b20a6a1f5.jpg https://cimg3.ibsrv.net/gimg/www.cor...a4e6b4fdf2.jpg https://cimg0.ibsrv.net/gimg/www.cor...d97c9d88e0.jpg https://cimg3.ibsrv.net/gimg/www.cor...7b493f80bb.jpg https://cimg4.ibsrv.net/gimg/www.cor...7ee77ad9b9.jpg https://cimg5.ibsrv.net/gimg/www.cor...ed0c4e1c12.jpg |
Originally Posted by STL Mike
(Post 1598354180)
is that your star mechanic? did she finish her apprenticeship? nice write-up as i will probably be doing a clutch next year. |
Yup, she's one of my 2 stars! Doesn't enjoy hanging out in the garage with me as much as I wished, unless she's riding her hoverboard!
:lurk:
No Vne.....Bad ass plate. What do you fly?
Retired Blackhawks, thinking about getting back into them. Not many people recognize the plate!
I'm a pilot test engineer for boeing on the P-8 simulators, still do the Navy Reserve thing (Maintenance Officer). I get it! One of the best plates I've ever seen.
[Yep QUOTE=STL Mike;1598409603]I'm a pilot test engineer for boeing on the P-8 simulators, still do the Navy Reserve thing (Maintenance Officer). I get it! One of the best plates I've ever seen.[/QUOTE] :cool::cheers: |
I love the plate as well! You can probably tell why from my profile pic. |
Ambitious projects for sure, G/L.
In case it wasn't thought of, as long as rear's out think about installing a remote bleeder. Might save some headaches, many here recommend 'em if/when rear's ouit. :cheers: |
Yup, got one with the Monster clutch kit.
Good to see another Boeing guy on the forum. Looks like you have a fun project in the works.
yup, same to you!
Last night, I got the torque tube off and slave removed. My snap ring pliers were not big enough to remove the snap ring, so I need to grab a new tool on the drive home. |
(Post 1598415142)
One last suggestion, post this where C6 Z06 owners are. C6's Z06 forum: https://www.corvetteforum.com/forums.../?prefixid=z06 Many owners there have done the same work you are., and more Lots of good advice from solid longtime member-owners available, if needed. :cheers: |
Thanks for the suggestion landru, i im'd 2 mods to see if they'll accommodate the move.
Torque tube is disassembled and slave cylinder removed. I've not found a smoking gun as to why the clutch wouldn't disengage, but take a look. Also, I'm very inclined to change the couplers and bearings while I'm this deep, but the couplers and bearings look good to me. I was at the dealer today and priced the oem bushings/ bearings at $715. Holy shit! Gonna call RPM tomorrow, any other thoughts? https://cimg5.ibsrv.net/gimg/www.cor...92769aed68.jpg https://cimg1.ibsrv.net/gimg/www.cor...ddffc8b402.jpg https://cimg2.ibsrv.net/gimg/www.cor...9c49c08bad.jpg https://cimg4.ibsrv.net/gimg/www.cor...1faa16a903.jpg https://cimg5.ibsrv.net/gimg/www.cor...b177342012.jpg https://cimg4.ibsrv.net/gimg/www.cor...0689bedce9.jpg https://cimg8.ibsrv.net/gimg/www.cor...3c329ed1d7.jpg https://cimg9.ibsrv.net/gimg/www.cor...f299a38cf4.jpg |
More pics
Very nice.. Welcome... Love the way you just jump right in and start tearing shit apart. Wish I had that talent. Keep us posted on progress.... I too am Military... 31 yrs US Army..
Not a pilot, nor do I work on Blackhawks... BUT I have been on more than I can count... Also fast roped out of a few... ;) |
Right on! Thanks and happy to be here.
Will be calling RPM here in a bit to get pricing on the torque tube replacement parts. |
