Who has made the switch to 3:75 gears?
Hey guys,
I found a small leak point on the D44 while under the Z today. It's not a rapid leak, just enough to make the collar around the driver side yoke look a little wet with a light on it. So looks like I found a way to blow my tax return in a few months. The car is only a weekend driver toy so it's not a huge priority right now but curious to know what a set of 3:75 gears would do. Who has made the switch? I was already considering this but now I have more of a reason to go through with it. I have heard of Ikerd's and I checked them out for the full rebuild kits and gear sets. So I have a place to source the parts but curious also if there's a builder who could be trusted to put it together and not have to worry about it howling. |
:flag:
Haibeck swears by the 4:10’s, http://www.zr1specialist.com/HAT%20W...ucts/gears.htm I had them in my last car and plan to up grade the current one as well. It made a huge impact on day to day drivability. The car felt much more responsive and 6th gear was now usable. I’m sure the 3.73’s will help but check out 4.10’s before you make a final decision. H :cheers: |
Originally Posted by FASTAZU
(Post 1598363170)
Most will say go with 4:10s but I went with 3:73 and they work great for my diving style. Had Marc do them when the car was at his place for the 500hp package.
http://www.zr1.net/forum/showthread.php?t=22970 Most likely old reading for the OGs around here but I'm having fun with it. |
Originally Posted by 1985 Corvette
(Post 1598364103)
3:73 is what I meant, I think I had the existing 3:45s on the brain making the title and OP. I found a rather extensive discussion on the 4:10s vs 3:73s over on the registry forum.
http://www.zr1.net/forum/showthread.php?t=22970 Most likely old reading for the OGs around here but I'm having fun with it. I just went with 4.10s and bigger front and rear 18 tires make sure you stay within .75 front to rear diameters or you'll throw a traction control code Phil got around this by machining a custom reluctor gear to run 345 tires in back which were probably 1 inch or so bigger than the fronts enough to make the system unhappy |
I agree with most--I went with 4.10s and they seemed perfect. Hard to see why Chevrolet did not make them optional like they used to do in the old days but I am sure it was emissions related. Did them on the '93 fairly soon after purchase and they were the first thing I did with the '95 along with a Corsa exhaust and a short shifter. Really improved around town driving and the only racing issue is that you need to shift into fourth at the drag strip. I thought about the 3.73s and researched it a bit but concluded 4.10s would be best. --Bob
Originally Posted by ZR1Bob
(Post 1598378633)
I Like 3.73s I think its perfect. I took out the 4.09s in my Lt1 car for 3.73s with 480rwhp and 8k rpm limiter the 3.73s were perfect and allowed 1st gear to be useful with an actual street tire that I could go high speeds and corner with too. 4.09s even with bolt ons on an LT1 got real tiring real fast. with the 388 stroker it was a joke. I don't like the ratios in the zf its like a 4 speed to me. I hate that 5th is pretty much an overdrive so I prefer stock gears. topping out 4th is fast enough and I can use 5th for top speed which isn't often. Plus longer gearing = less shifts at speed so for how I like to drive I prefer to shift less among other reasons
With 19s on the back, I needed to go to 4.10s just to be close to matching the overall ratio of stock wheels and 3.45s. It makes 6th more usable w 80mph putting the motor at about 1900rpm. |
I love the fun I have around town with the 4.10s. But my car is mostly stock
If you go with 373 it will cut a whole second of your 1/4 et best bang for your buck. I have a pumpkin with 273s I will sellfor $500 or use for the 1000 core they charge here at Wcc and get a new set of 411s |
My first car was a 91 with Watson small primary tube headers, no cats, and a 3" early B&B exhaust, and a custom chip. It had the 4.10's and it ran great. I didn't have anything to compare it to as I hadn't driven a car with the 3.45's. At Bowling Green one year I was on the highway heading to the barbeque when I got into a little friendly competition with a stock geared car. I remember that we were dead even up to about 100 when I just started walking away until I let off around 150. My current car is 525 h.p. that Marc did and I think it will be better with a set of 4.10's.
3.73 isnt really enough that youll feel it or feel good about the money spent. 4.10 isnt as steep a gear as it sounds its just right.
Went from 3.08 on another car to 3.73 and regretted it...week later did the 4.10 and all was right. If you got a car that redlines say under 6k then 4.10 isnt always best |
I'm still undecided. Switching back and forth between my 3.45 510chp and Ami's* 4.10s ~ 510 hp...its a LOT OF GEAR ROWING, especially in the mountain type twisty roads. It is great to run "The Dragon" in 2nd gear and let the rpm range of the LT5 handle the curves w/o having to row the gears (so much).
Of course, I'd like to have more torque throughout the rpm range. So, I guess its the old conundrum between gears and HP mods. 'The jury is still out'. *Pete's cams, but smaller porting. Would be interesting to put it on a dyno someday out of curiosity. |
Originally Posted by Paul Workman
(Post 1598487383)
How about a 391 in your car, leave the gears alone? lol |
Originally Posted by -=Jeff=-
(Post 1598488138)
(Post 1598489612)
Oh, SUCHA novel idea! (NOT!) :cheers:
too bad bad there isn’t a PPP(Pete’s Payment Plan) for a PPP (Pete’s Performance Package) not sure that that would fit under the tree as a Christmas gift either 😀 |
(Post 1598489787)
lol.. too bad bad there isn’t a PPP(Pete’s Payment Plan) for a PPP (Pete’s Performance Package) not sure that that would fit under the tree as a Christmas gift either 😀 |
LT5 layaway plan. Participating member.
