AMT Motorsport Holiday Sale - 15% off EVERYTHING we make
Happy Thanksgiving to all!
We're running the only sale we do all year long starting 8pm EST tonight and all thru Cyber Monday. Every AMT product on out site is available at 15% off when you use coupon code "cfholiday" at checkout. This is your only time to save some serious coin on big ticket items like our Spherical Bearing Kit and Full Floating Rotors, and will also yield substantial savings on Camber Kits, Spacers, Motor Mounts, and Seat Mounts. We're also discounting Sparco seats and BK Harness bars up to 10% off. Why if a fellow was looking to set his car up with full monoball suspension, a pair of seat mounts and Sparcos, and a BK harness bar that fellow could be saving almost $1000 on the complete setup. It's savings madness!! Head to www.AMTMotorsport.com to take advantage of the discounted pricing. We've listed some of our products below in case you may be unfamiliar with what we do. Happy Thanksgiving to everyone! C5-C7 Adjustable Camber Kit https://cimg4.ibsrv.net/gimg/www.cor...329126ccf2.jpg The product the launched our company is available for all C5-C7 Corvettes. If your car sees any serious track time than a camber kit is virtually required equipment. Set your alignment once and never worry about it again. Everything is USA made and guaranteed for life. For more info on C5 and C6 camber kits follow this link. For the C6Z/ZR1 head over here. And to solve problems for all C7s head this way. Full Floating Rotors for C5 and C6 Base Corvettes https://cimg5.ibsrv.net/gimg/www.cor...3192e53dde.jpg If you're sick of cracking solid one piece rotors at a single day at the track then get yourself a set of AMT Full Floaters. Rotors are DBA5000s, the hats are 6061 Aluminum black anodized and laser engraved, and the hardware is 17-4PH stainless steel. Replacement rotors are $200 each but no one has had to buy one yet. Normal price on these is $800 but with discount code 'cfholiday' you're looking at a scant $640. You will not buy a better performing rotor for less money. For more info and to order click here. C4-C7 Wheel Spacers https://cimg4.ibsrv.net/gimg/www.cor...04956efe78.jpg We offer 4 different sizes of wheel spacers. Our 1/4" spacer uses the lip of the stock hub for centering and can be used with stock length studs. Our 3/8" spacer pushes the wheel out a smidge further but the ring on the hub is no longer effective. We recommend going to the 2.5" ARP studs if you're using a 3/8" spacer. We also offer 3/4" and 1" spacers with a machined lip for centering. These spacers should use the 3.25" ARP studs. ARP studs are available on our website and if you buy a set of spacers and studs, we can install them in your hubs for free. The studs require a press to get in and out so if you don't have one just send us your hubs and we'll tackle the job for you. For 1/4" and 3/8" spacer head this way. For 3/4" and 1" go that way. C5-C7 Monoball Control Arm Bushings https://cimg4.ibsrv.net/gimg/www.cor...762a18e170.jpg If you're looking for slot-car like handling for your Corvette then a set of monoballs is probably the best money you can spend on your car. The car is transformed and so much easier to drive on the limit. We use the best materials available and custom fit each part to your YOUR control arms. All you have to do it send them to us and we take care of the rest, and return shipping is included. For a detailed video on how intensive our process is, check out the video below highlighting the process. Pricing is $2500-2700 depending on your car, which means you save $375-$405 depending on your setup. That's a whole entry fee for a track weekend people! Follow this linkif you would like to turn your car into a race car. C5/C6 Vulcan Motor Mounts https://cimg5.ibsrv.net/gimg/www.cor...33bc238c4d.jpg These mounts are now on their third variation and better than ever. A single bolt keeps your motor from moving fore and aft, while vulcanized rubber dampens the vibrations so they're not as harsh as solid mounts. We now use a hard anodized 6061 center section to keep the 2 rubber pucks in each assembly where they belong. Make no mistake these mounts do not feel like the pillowy soft oil-filled gushiness of the stock mounts. You are definitely going to feel more of the engine with these mounts, but your 350 lbs lump of a motor will not be moving all over your engine bay either when performance driving. Follow this link to order yourself up a set. C5-C7 Ultralow Seat Mount https://cimg7.ibsrv.net/gimg/www.cor...9cc2c875f5.jpg This is the lowest, strongest, safest billet seat mount available for the Corvette. It will put your seat on the floor if needed. Using this mount with the new Sparco QRT-R seat I gained almost 2 inches of head room over MTI rails with a Sparco EVO. Our integrated sub belt takes the guess work out of installing your 5 or 6 point harness. On a side note the structural integrity of these mounts were just tested by a customer of ours in a 150mph crash on track. He made multiple impacts with the tire wall including a side impact and the seat mounts and Sparco Ergo did precisely what they needed to do - keep him safe. Follow this link to get yourself low. Other Stuff https://cimg4.ibsrv.net/gimg/www.cor...d699f9ddb.jpeg As mentioned Sparco seats and BK Harness bars are already discounted 10% on our site, so you can be saving a whole bunch of money on a complete seat mounting solution. The Sparco Ergo is a full $100 below retail. Head this wayto see all of our interior parts for your Corvette. Thanks all for a great 2019! We've got a couple neat things coming up for the end of this year and beginning of next year that I'll be excited to share with you all. Corvette Forum has made our small company what it is today and I thank you all for your continued support! |
Alright folks I wanna sell some more monoballs. From now through Monday every full set of monoballs comes with an Ultra Sexy, Super Nice AMT Motorsport Spyder Jacket. Just let me know your size in the order notes and I'll order one up for you. That's a $150 value on top of the $375+ savings on the monoballs. Just remember to use code "cfholiday" at checkout
https://cimg4.ibsrv.net/gimg/www.cor...b87f82b016.jpg |
Last chance to save folks! After tonight there won't be another 15% off sale for another 362 days. Just use code "cfholiday" at checkout. And don't forget, every set of monoball bushings comes with an AMT Motorsport Spyder jacket! Thanks all for your support!
