Couldn't even make it to the first oil change
I am without words!
I might get words if I knew what you were talking about. Elmer |
:confused:
You are facing North
You have almost a full tank. You have driven the car a total of 319 miles You have 328 miles (Approx) left to drive on this tank of gas You are stopped. Idling at 650 RPM In V8 mode Temp around 200 OIl pressure 26 PSI In SPORT mode Car is cold per the tach but the temp says warm is that the problem? |
fuel gage. left my house, gage was reading 1/4 tank. I was 99% sure I had just put gas in it the last time I drove it and it should have been at least 3/4's. I was going for 80 mile drive so I stopped to put $20 in. it would only take $19. when I turned car back on, gage pinned itself on E.
man I am an idiot. im deleting this. read the gage wrong. im leaving now with my tail between my legs.
Originally Posted by ant812
(Post 1598395917)
Blame it on the booze, your age, or the woman in your life!
If it helps, this happened to someone else earlier this year. Your initial post was confusing so you can work on that? |
Were you assuming that you would get 500 miles on a single tank of gas?
in my defense, I have never seen a fuel gage that reads right to left, EVER!
Originally Posted by falcon5619
(Post 1598395937)
Elmer |
(Post 1598395917)
(Post 1598395943)
Aaaahah! Faulty gauge! Elmer |
Don't you mean left to right?? Full is on top and moves to the right as you are driving.
(Post 1598395925)
Does this have anything to do with righty tighty - lefty loosey?
OK, I pushing now but I'm only 7 posts away from 10,000!
Elmer |
(Post 1598395943)
Originally Posted by eboggs_jkvl
(Post 1598395980)
Elmer |
