Dyno results: ZR1 w/headers, American Racing Longtubes
The ZR1 wrapped up the track season, with stock manifolds, a few weeks back. Very fast, consistent, and always a blast to drive no matter the venue. We opted to try and further the ZR1 even more.
A set of American Racing 2" long tubes are now installed. We fully anticipated more power across the chart. Sometimes, there are surprises. Check out the results... https://cimg5.ibsrv.net/gimg/www.cor...9920cc358d.jpg |
Nice work! What wheels and tires are those? |
You mention the car is actually adapting to the headers. The dyno results seem to back up that statement. Is it the oxygen sensor that is gradually changing or what is it that is capable of “learning” what the engine needs? |
Nice documentation. Looks like you’re making a good chunk over 800 at the crank. Well done! :thumbs: |
Nice video Josh, impressive, did the power stay that high after shut down and restarts?
What does the timing look like for both the X-pipe and headers? |
Great results! What octane fuel in the vehicle? Do the ARH headers then go into high flow cats?
Best Regards, Dave |
Being knowone can tune these zr1s yet i was just curious whats the leanest afr youve seen on the dyno with these mods
That's the way to do it......put the car on the track follow by the dyno.
No secrets with what the ZR1 would be capable of with calibration. Staying excited and optimistic for access! Thank you for the questions.
Originally Posted by SilveradoSS500
(Post 1598398791)
Originally Posted by Rinaldo Catria
(Post 1598399088)
Baselines without headers compared to the later runs with them installed, timing went up 1*. Peak timing was at 19.8* with the headers on. The 19.8* of timing does not appear until the last few hundred RPMS of the pull. Timing starts at 8* and gradually ramps up. The gradual increase is consistent with stock baseline pulls and dyno pulls with the intake and xpipe. The AFR delta was about a tenth, 11.38 to 11.46 peak. There was a .05 change down low. Leaner, bet very minor change overall but enough to make gains. The change in peak boost appears to be almost 1psi lower from the headers being installed. We are further reviewing data, and will be able to provide more insight soon.
Originally Posted by Too-Fast
(Post 1598399376)
Originally Posted by Bob U
(Post 1598400113)
Originally Posted by BlueDevilZ51
(Post 1598403956)
Originally Posted by Vernon
(Post 1598399173)
Nice documentation.
Originally Posted by Dave Schotz
(Post 1598400841)
:lurk:
Originally Posted by HorsePowerAddicts
(Post 1598407917)
93 oct, and there are no cats. |
Code, CEL, is present. No major issue, visually an annoyance.
