-   C7 Tech/Performance (https://www.corvetteforum.com/forums/c7-tech-performance-169/)
-   -   Tow Hooks Installation for 2016 (https://www.corvetteforum.com/forums/c7-tech-performance/4217759-tow-hooks-installation-for-2016-a.html)
HorsePower Junkie 11-30-2018 05:47 PM
Are there threaded receptacles to install Tow Hooks already there behind the front grill and the rear bumper on a 2016 base Stingray?
ErnieN85 11-30-2018 06:31 PM
yes
Dcasole 11-30-2018 10:20 PM
How about a 2015 Base
ErnieN85 11-30-2018 10:56 PM
Not sure pop the cover and have a look
robert miller 12-01-2018 11:50 AM
All z51 and z06 have them from 2015 and on 2014 z51 didn't have the front. Base model don't have the front I had to get the parts from ZL1 that sales the tow hooks & I put it in the front. THEY ALSO SALE THE PIECE THAT IS NEEDED TO DRILL A HOLE OUT THEN YOU ONLY HAVE TO PUT A NUT WITH A WASHER ON BOTH SIDES OF THE FRONT BUMPER BRACE TO HOLD THIS IN PLACE... Robert
malexand123 12-01-2018 12:02 PM
My ‘17 base stingray had neither front nor rear threaded.
dbletap_ed 12-01-2018 04:29 PM
My 17 Stingray Z51 the front is threaded. I have not pulled the rear cover to check that one due to fear of scratching the car.
HorsePower Junkie 12-03-2018 03:12 AM
ttt
Dcasole 12-03-2018 06:44 AM
Originally Posted by HorsePower Junkie (Post 1598434609)
ttt
Your question was already answered by Ernie and the others I thought
2014 and 15 Z51 , ZO6 , And ZR1 have the tow hook receivers and in 2016 the Base was added to the list
Dave
HorsePower Junkie 02-10-2019 03:24 AM
Anyone have a 2016 base C7 that has installed tow hooks??
Can you please confirm if the threaded receivers are already there in the front and rear are there?
Max Bet 02-25-2019 10:25 PM
A little late with my reply, but I have a 2016 Base. I don't believe there is a tow hook receptacle in the rear, and I"m 100% certain there isn't one in the front because I installed the aftermarket receptacle from ZL1 Addons.
KGrant 03-30-2019 10:26 AM
I don’t have the tow hook receiver from the factory and didn’t realize when I bought my Tow Hook.
So I’ve studied the process to remove the front fascia and bolt on a receiver but didn’t want to go through the process to remove my front aero package and rivets etc.
I don’t track my car and I just like the look for appearance reasons only so I needed to be creative to find a solution and here it is.
The hardware is silver but this is the trial run and I drove the car about 60 miles to see how it would hold up or stay in place and it worked perfectly. I now will try to find the washers in black or just paint the silver ones black so that they blend in which I likely will do since HomeDepot didn’t have black ones.
Disclaimer Alert! This Install is for Appearance Looks ONLY and CANNOT be used to tow!
https://cimg5.ibsrv.net/gimg/www.cor...58ca4a3f3.jpeg
https://cimg1.ibsrv.net/gimg/www.cor...4f195a422.jpeg
https://cimg0.ibsrv.net/gimg/www.cor...f2d894d0ac.jpg
BrunoTheMellow 03-30-2019 01:11 PM
Originally Posted by ErnieN85 (Post 1598422652)
yes
Incorrect. Base models don't have it.
BrunoTheMellow 03-30-2019 01:14 PM
You don't have to remove front aero bits nor rivets to pull the front bumper. It all comes out with the bumper, if anything, undo the undertray at the k member. If you have stage 3 splitter end caps you have to disconnect them but that's easy.
And in my opinion, tow hooks for looks are about as ricer as it gets.
JT Corvette 03-30-2019 02:00 PM
why would your aero package affect the removal?
